1994 Corvette H41 code
Old Feb 17, 2010 | 12:10 PM
Y-ME's Avatar
Y-ME
Default 1994 Corvette H41 code
Ok last year I go into the garage start up my 94 and the second I put her in drive she cuts off won't start.
I put in a new ignition control module and she runs, but I get a code H41 bad ignition module ground. it's not on all the time it is sporadic sometimes coming on when I let off the gas and off when cruising.
I took it to a local american car only shop, I did not tell them about the new ig mod. they said it could need a new one of those or maybe a new ecm which a dealer would have to determine.
Well now my emissions are due and I need/want this light off without going to the dealer.
Any idea's?
Old Feb 17, 2010 | 12:51 PM
pcolt94's Avatar
pcolt94
Have you ever cleared the codes. You can use the onboard diagnostics or remove the battery cable for 30 seconds. I would at least start there.
Then I might clean all connections at the ICM including the ground.
I might also clean the connector at the PCM that relates to the ICM connections.
AT some point check for codes and see if it reappears
Old Feb 18, 2010 | 09:24 AM
Y-ME's Avatar
Y-ME
All thats already been done.
To 1994 Corvette H41 code
