Brake Pads
Old Feb 20, 2010 | 03:29 PM
jan-erik's Avatar
jan-erik
Default Brake Pads
I have an 85 z-51 4+3.
I have Hawk HPS and would like better brakes as the 85 brakes sucks as stock.
Would changing the Hawk HPS to Hawk HP Plus give significant better brakes. There are of course some squeeking noise and rotor wear from them , but if the brakes are much better with HP plus I would accept the cons of squeek and wear
Anybody with experience regarding HPS and HP plus.
Old Feb 21, 2010 | 11:29 AM
jsinga's Avatar
jsinga
J55 or C5 upgrade depending on if you have 17" wheels.
C4 J55 will fit under Z51, Z52 enkie 16x9.5" wheels. Used parts new rotors and adapter bracket from Corvette Central cost me @$450 to do J55 on my 87.
JS
Old Feb 21, 2010 | 12:27 PM
Aardwolf's Avatar
Aardwolf
You posted a thread about this already.
http://forums.corvetteforum.com/c4-t...-85-4-3-a.html
Old Feb 21, 2010 | 02:20 PM
runner140*'s Avatar
runner140*
I've got well over 50,000 miles on my Hawk HPS pads and I think I've got alot to go. Best pads ever used.
Old Feb 21, 2010 | 05:45 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
If you hav JL9 brakes the HPS pads are perfect. Something else in the brake system is contributing to your "bad" brakes.
I had an 88 with the JL9 brakes, ran PFZ pads at Beaver run after flushing ALL my brake fluid and slowing from 100 ish to turn in to turn 1 was a NON event. They worked great.
10 years later I have a 92 with J55 brakes. I run real race pads and this winter I replaced everything but the hard brake lines. Brakes were terrific at CMP last weekend.
I drove a Ford Flex last week on travel and those brakes SUCK worse than any Corvette brakes. I kept having to remember to brake early.
Old Feb 21, 2010 | 07:00 PM
ride250s's Avatar
ride250s
JS
What Wheels? I have an 87 also, wish I could upgrade the brakes without new wheels.
Old Feb 24, 2010 | 09:08 PM
jsinga's Avatar
jsinga
factory orginal Z51 or Z52 option cars have 16x9.5" wheels made by enkie. They will just barely clear the J55 13" brakes. Don't get the GrandSport calipers. I had to clearance the top of the caliper a little.
JS
Old Feb 24, 2010 | 10:02 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have C5 brakes on the front. what a difference. now it stops. I have finally done a panic stop where the antilock activates.
You don't need it if the front brakes are ineffective.
If you want great brakes, try wedging in a C5 dual diaphragm booster and C5 brakes...You can't run stock wheels because the brakes are too big......So I have C5 wheels as well.
Old Feb 24, 2010 | 10:37 PM
l98tpi's Avatar
l98tpi
Max G’s
Your response must have been overwhelming with the elaborate graph. Bottom line for quick braking- clean, fresh fluid in system via gravity bleeding, good quality brake pads, and good tires.
To Brake Pads
