Engine quit
Old Feb 21, 2010 | 05:10 AM
85 paulie's Avatar
85 paulie
Cruising
Default Engine quit
I was just pulling into my driveway early this morning when the engine in my 85 just quit?? Tried to restart it, nope, turns over, but won't start. Gas gauge was reading about 4 gal. and it didn't throw any codes?? Any help would be great, Thanks
Old Feb 21, 2010 | 07:45 AM
HdRider04's Avatar
HdRider04
Are you sure your gauge is correct? Squirt a little starter fluid in the TB and see if she catch's, If not check for spark and fuel pressure to start with. Hope it's something simple
Old Feb 21, 2010 | 10:15 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
squirt gas in there, not starter fluid.
Old Feb 21, 2010 | 11:31 AM
John A. Marker's Avatar
John A. Marker
Check for basics:
1) Check for fuel at the rail. Schrader valve is on the passanger's side of the engine. Remove cap and press in on the valve stem (looks like a tire valve). Got fuel?
2) Check for spark. Pull a plug wire, insert a screw driver into the boot and hold by the handle so that you have a small gap between the shaft and a ground, have someone crank the engine....GOT spark?
Two basics
Old Feb 21, 2010 | 03:01 PM
85 paulie's Avatar
85 paulie
Cruising
Went out this AM after the rain to check my car, and it started right up??? Everything checks just peachy, maybe something got wet, or the car's possessed?? Thank's for all your response's
Old Feb 21, 2010 | 05:38 PM
ex-x-fire's Avatar
ex-x-fire
Next time you take it out don't forget your AAA card.
Keep in the car a fuel press. tester & a spark tester. It'll happen again.
Old Feb 21, 2010 | 06:43 PM
Harsh20's Avatar
Harsh20
Was it raining when the car shut off?
you may have splashed water up on the starter and it found a naked wire or two. Once everything dried out you were able to start it.
if it wasn't raining when it shut off. take short trips till it shows up again and you get the issue solved.
Old Feb 21, 2010 | 08:16 PM
guido7834's Avatar
guido7834
I had a similar problem with my 87.Turned out to be a loose wire to the fuel pump just under the fuel filler door. It would happen sporadically then finally not start at all. Found it when I checked the pump. Apparently is a common problem, I've heard
Old Feb 21, 2010 | 08:34 PM
85 paulie's Avatar
85 paulie
Cruising
Damn, it happened again, it is a no fuel problem, as soon as i can I'll be tearing into the fuel pump, turned it on and there was no fuel coming out??? Don't know if it a wire or the pump?? maybe fuse??
Old Feb 21, 2010 | 09:23 PM
1stL98's Avatar
1stL98
i had a similar situation on my 85,after checking every possible cause it ended up bein the oil pressure switch,which wud shut down the fp,replaced it with an ac delco unit due to it bein discontinued by gm.it hasnt done it again
Old Feb 23, 2010 | 10:25 AM
85 paulie's Avatar
85 paulie
Cruising
Hey everybody, I would like to thank everyone who responded to my problem, it did turn out to be the fuel pump, Thanks, you guy's are great.
To Engine quit
