i jump started the car, turned it off., wiated and about 2 hours later tried to sart it. all the prestart light s came on the the car just went dead nothing lighting up and no sounds
Battery is probably dead, you need to charge it, not just idle for a couple minutes. Starting the car actually weakened it, hook up a battery tender for a day or two, if it isn't OK after that, get a new one.
clean up all your connections, including the ground cable where it attaches to the engine, as well as the + cable at the starter. Sounds like a bad ground, but you may as well clean them all....
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Usually a VATS problem will not go away so easily.
