major differences between 52mm and 58mm TB?
Old Feb 23, 2010 | 11:22 AM
snoopdan's Avatar
snoopdan
Default major differences between 52mm and 58mm TB?
Looking at getting the Holley throtle body replacement for my 86, what is the primary difference between the 52 and 58mm models besides the obvious?
Old Feb 23, 2010 | 11:23 AM
Pwnage1337's Avatar
Pwnage1337
i don't think there is any difference between the two besides the size. Is your car stock?
58mm would be absolute overkill unless you are running it on a modified motor.
Old Feb 23, 2010 | 11:27 AM
snoopdan's Avatar
snoopdan
other than headers, and a turbo 350 transmission conversion and 120 shot of nitrous - no head work.
Old Feb 23, 2010 | 11:28 AM
engle1147's Avatar
engle1147
Make sure you get the correct year TB app....the linkages are different for a few of the 80's years.
There is a slightly modded BBK 52mm in the F/S section.
Old Feb 23, 2010 | 11:31 AM
snoopdan's Avatar
snoopdan
yep im aware of the linkage issues. As far as that bbk in the f/s section I don't like that its been hacked on already.
I run a throtle plate for my nitrous, I wonder if one of these Holley 58mm's will allow me to use the plate...I couldn't imagne why not.
Old Feb 23, 2010 | 11:38 AM
cv67's Avatar
cv67
St. Jude Donor '05
Think the stock one would be fine for what youre doing.
Old Feb 23, 2010 | 11:46 AM
snoopdan's Avatar
snoopdan
really? hmm..that sucks.
Old Feb 23, 2010 | 12:00 PM
cv67's Avatar
cv67
St. Jude Donor '05
Saves money=good
Old Feb 23, 2010 | 12:04 PM
snoopdan's Avatar
snoopdan
Saves money=good
no, because i'll spend it on new door panels or carpet
Old Feb 23, 2010 | 12:34 PM
ch@0s's Avatar
ch@0s
Just send it to me, I will send you a sticker you can put on that TB to get you HP.
It says, "Grand Sport"
Old Feb 23, 2010 | 01:28 PM
missinganova's Avatar
missinganova
I love the throttle body threads.
You know what would be great? If someone with access to a dyno could settle and answer these questions with finality.
Run a stock, sound L98 with stock, 52mm and 58mm throttle bodies and record RWHP.
Run a slightly modified L98 (chip, cam, porting, headers) with all three throttle bodies again and record RWHP
Run a highly modified L98 (chip, heavy cam, porting, headers, stroker, NOS or blower) with all three throttle bodies again and record RWHP
You still can't convince me that anything more than stock is needed until you start moving a lot of air.
Old Feb 23, 2010 | 01:54 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I'm sure the manufacturers have already done that. check their websites
Old Feb 23, 2010 | 02:43 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
The problem is you can dyno a car ten times in a row without changing a thing and get ten different set of numbers.
Old Feb 23, 2010 | 03:09 PM
JAKE's Avatar
JAKE
I found a site where a dyno test was done that showed a power increase of less than 10 when a larger TB was installed, but only within a 1000 rpm band, IIRC 5000/6000. As I recall, it was on an engine with only bolt on mods.
One of the mags did the engine build and test and I'll try to find and post the link.
On a personal note, I've run all three, 48, 52 and 58 mm. Going from 48 to 58 showed me an acceleration increase so dramatic that I swapped it with a Forum member for his 52.
One thing members don't seem to consider is that even though max power may not increase, the fun factor does. When moving to a larger TB, for every incremental increase in throttle opening, more air is allowed to enter the engine (when compared to a smaller TB) which causes the car to accelerate faster. Up goes the fun factor.
In the case of me running the 58, the change from a 48 was so dramatic I decided to move DOWN to a 52 to better be able to modulate the throttle and NOT blast around like Speed Racer.
Jake
Old Feb 23, 2010 | 03:22 PM
snoopdan's Avatar
snoopdan
Originally Posted by JAKE
I found a site where a dyno test was done that showed a power increase of less than 10 when a larger TB was installed, but only withing a 1000 rpm band, IIRC 5000/6000. As I recall, it was on an engine with only bolt on mods.
On a personal note, I've run all three, 48, 52 and 58 mm. Going from 48 to 58 showed me an acceleration increase so dramatic that I swapped it with a member for his 52.
Jake
See that's good info right there. I use my car mainly as an 1/8th mile racer so this might work for me if I go all the way up to a 58mm. I've had the picture of a polished holly 58mm on my desktop all day and have been considering the leap.
Old Feb 23, 2010 | 04:49 PM
JAKE's Avatar
JAKE
Many times guys only compare what we refer to as "peak to peak" numbers in making TB decisions. When I moved to a 58, I began a new learning curve to re-learn how to control and regulate my right foot. The same pedal pressure I had become accustomed to when using the 48 was out the window. Using that same pedal pressure, I'd blast away from stop lights and had folks looking at me like I was a drunken teenager, LOL
Sort of the same thing happens when comparing head flow numbers. Guys tend to look at and post on the max flow numbers and completely ignore all else, like port volume, mid-lift flow, bore size, etc., all of which effect how the heads will actually perform when installed on the engine.
As I recall the next biggest issue was getting the accordion to fit over the 58.
Jake
Old Feb 23, 2010 | 05:32 PM
dogfish246's Avatar
dogfish246
I wish there was a comprehensive dyno run/test of all the different mods to a stock engine to see whats real and what fake!
For example, is less back pressure good or bad! (no one answer this)
To major differences between 52mm and 58mm TB?
Old Feb 23, 2010 | 08:59 PM
LT4BUD's Avatar
LT4BUD
Gain is going to depend a lot on other mods.....but done right the 58 is going to give you more power, done wrong you might actually loose power
I did 58, at that time both were the same price , except with the 58 you need to mod your intake to match...
An old thread showing the importance of doing it right..
http://forums.corvetteforum.com/c4-t...plugs-ect.html
I would think the same concept would apply to the L98
Old Feb 24, 2010 | 07:42 AM
snoopdan's Avatar
snoopdan
anybody know of any good port matching tutorials for the 58mm setup?
Old Feb 24, 2010 | 08:07 AM
ddahlgren's Avatar
ddahlgren
Quote 'One thing members don't seem to consider is that even though max power may not increase, the fun factor does. When moving to a larger TB, for every incremental increase in throttle opening, more air is allowed to enter the engine (when compared to a smaller TB) which causes the car to accelerate faster. Up goes the fun factor'
You could just step on the pedal faster..LOL.. Anything bigger than what you need just makes it harder to drive .. What is the point in that.
