02 sensor questions
Old Feb 24, 2010 | 12:32 PM
gotta 94's Avatar
gotta 94
Default 02 sensor questions
Is it possible to remove and clean the front o2 sensors on my 94 vette instead of replacing them right now?
Old Feb 24, 2010 | 12:34 PM
jhammons01's Avatar
jhammons01
Mine (singular in an '84) was ~$20......Are the '94s expensive?
Old Feb 24, 2010 | 12:41 PM
gotta 94's Avatar
gotta 94
Long story short, ive been quoted 119 each plus 90 bucks for labor, i just replaced full opti, plugs, wires and waterpump myself two weeks ago and now i the car is throwing a code for a bad left 02 sensor, im outta cash and looking for a temp quick fix,
Old Feb 24, 2010 | 12:46 PM
runner140*'s Avatar
runner140*
About $35.00 each purchased at a discount auto parts online.
Old Feb 24, 2010 | 12:49 PM
runner140*'s Avatar
runner140*
Contact "Oxygen Sensors"...on line $35.00 shipped
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
If they're the factory sensors,you will find they are difficult to really physically clean due to the bulbous cover protecting the sensor itself unless you soak it in something to try and decarb the sensor and manage not to harm it in the process. Sensors are fairly cheap unless paying dealer cost to not replace them if they have any age at all on them or you suspect a faulty one from codes being set or show to be faulty or lazy on oscillation thru scanning.You can get these heated O2 sensors aftermarket on line for about 34 a piece shipped to your door in denso or delphi brands which have so far worked fine for me.
Rick
Old Feb 24, 2010 | 12:52 PM
PDQUIK95's Avatar
PDQUIK95
It really irks me to see how people get taken by the stealership or some repair shops on parts and labor for something very simple and cheap to fix.
RG
Old Feb 24, 2010 | 01:10 PM
gotta 94's Avatar
gotta 94
Much appreciated I know what you mean, Doing all the prior work to my vette was a big step for me and i have to say thanks to all of you guys on here made it possible for me to fix the car. I heard so many stories that the universal ones have to be assembled thats why they are so cheap. I spoke to a rep at corvette paramedics, reputable shop by the way, but even they said they cost over 100 bucks each and beware of aftermarket. Would autozone or Napa carry these denso or delphi
Old Feb 24, 2010 | 01:23 PM
PDQUIK95's Avatar
PDQUIK95
NAPA or Autozone may carry that type if you need them in a hurry. The 34 dollar price on line is for the exact heated O2 sensor type connector style,not the universal type, so no need to modify them.
RG
Old Feb 24, 2010 | 01:38 PM
gotta 94's Avatar
gotta 94
ok will do, many thanks, last questions do you know where the wires lead too? Do they lead to the opti?
Old Feb 24, 2010 | 03:51 PM
pcolt94's Avatar
pcolt94
Sensors go back to the PCM where the voltages are used for fuel calculations. Then the proper pulse width is fed to the injectors.
O2 sensors should never be cleaned as I have read, it will ruin a good one. It's not that they get dirty (only), but the material that develops the voltage gets tired also with age and just does not respond and swing the voltages correctly.
Saving money is nice, but for the work involved and the impact the O2s have on the engine performance and running, I think new ones should be absolutely installed.
Old Feb 24, 2010 | 04:57 PM
gotta 94's Avatar
gotta 94
Ok I'm buying new ones this weekend, give me something to do with all the snow coming agian. thank you very much.
Old Feb 24, 2010 | 07:24 PM
jhammons01's Avatar
jhammons01
Yup, just looked, the '94 is $32.
The '84 is $19.99
Old Feb 24, 2010 | 08:34 PM
pcolt94's Avatar
pcolt94
Great. You're doing it the right way. And the cost is fairly reasonably as compared with some other repairs.
A bit of advice doing it yourself. Get a O2 socket other than the normal socket. Harbor Freight has one that you can get a wrench on sideways. I only suggest this because you might not have the clearance for a standard O2 socket.
Good luck, get rid of the snow
Old Feb 24, 2010 | 09:54 PM
gotta 94's Avatar
gotta 94
Luckily my neighbor has all the tools i dont have and he has the socket you are referring to, thank goodness. I asked him earlier today and he has it. I called a vendor and i am getting a front set of densos, I might as well replace both, even though the left one is the little bugger acting up, right? I will keep you posted on my progress as always many thanks, in the spring we can talk about replacing the rubber seal all around lol
Old Feb 25, 2010 | 07:48 AM
runner140*'s Avatar
runner140*
AGAIN, "Denso" oxygen sensors are sold online for under $35.00.
Old Feb 25, 2010 | 10:49 AM
gotta 94's Avatar
gotta 94
Yup got it Densos, found online cheaper then store by my house, thank you.
To 02 sensor questions
Old Feb 25, 2010 | 03:31 PM
desertmike1's Avatar
desertmike1
Might not be the Sensor.....
Old Feb 25, 2010 | 10:27 PM
gotta 94's Avatar
gotta 94
what do you mean it may not be the sensor I pulled the codes bad heated 02 sensor on left side, please tell what you think it is?
I can smell the fumes and the gas mileage is horrible since i replaced everything
Old Feb 26, 2010 | 01:01 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Any suggestions?
