Click Click Click
Old Mar 9, 2002 | 02:01 AM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Click Click Click
Just started to notice a Clicking noice when i accelerate. the noise will not be generated if if I put in her "N". The noise sounds like the click click of a roller coaster going up the first hill, except higher pitch. When in gear the clicking will get fast with increase RPM's. Any ideas?
1984 Corvette
Stock
82000 miles
Thanks Will
Old Mar 9, 2002 | 08:19 AM
SlowJoe's Avatar
SlowJoe
Default Re: Click Click Click (flyinace2000)
Is it a rapid clicking (spark knock?). And in your situation, I wouldn't be accelerating too much! :D
Old Mar 9, 2002 | 10:32 AM
flyinace2000
Default Re: Click Click Click (SlowJoe)
sounds much more like a mechanical knocking noise. Its not a high pitch click either. it is very low.
Old Mar 9, 2002 | 10:42 AM
ittlfly's Avatar
ittlfly
Have you checked for codes?
Old Mar 9, 2002 | 10:44 AM
BBA's Avatar
BBA
Thats the first noise I had when the u-joints went out. Shortly after that, it got much louder and clicked whenever moving.
Old Mar 9, 2002 | 11:49 AM
flyinace2000
Default Re: Click Click Click (ittlfly)
Just started to notice the clicking about 36 hours ago...When i get back to school on monday i will hook up the computer to it.
Will
Old Mar 9, 2002 | 08:19 PM
flyinace2000
ttt
Old Mar 9, 2002 | 08:44 PM
BobMachus's Avatar
BobMachus
U-joints, bearings, nail/rock in your tire? Those would be my first guesses. My rear half-shaft u-joints started like a ticking/swishing from the back, then progressed to a blood-curdling shriek. Good luck
Old Mar 9, 2002 | 10:58 PM
ittlfly's Avatar
ittlfly
If no codes are set, then I agree with the above post and it is probably a u-joint as it happens when the car is underpower. (torque applied to the drivetrain)....and not when you "put it into N". NOT a fun job to fix but fairly straight forward. I did all 6 of mine a few months back. A beer or two makes it go easier. :yesnod:
[Modified by ittlfly, 7:00 PM 3/9/2002]
Old Mar 10, 2002 | 01:24 AM
flyinace2000
[QUOTE]If no codes are set, then I agree with the above post and it is probably a u-joint as it happens when the car is underpower. (torque applied to the drivetrain)....and not when you "put it into N". NOT a fun job to fix but fairly straight forward. I did all 6 of mine a few months back. A beer or two makes it go easier. :yesnod: [QUOTE]
I don't think a beer would go over to well in Auto Class. hahahaha
Will
To Click Click Click
