Shifter indicator
Old Feb 28, 2010 | 11:01 AM
surfer92's Avatar
surfer92
Default Shifter indicator
How do you get the indicator connected to the shifter after you take off the center console?
This was not one of GM's better ideas.
Old Feb 28, 2010 | 11:44 AM
Elrick's Avatar
Elrick
On my 86 it just sits in a little notched groove. You kind of have to be careful when you put it back in because nothing holds it until you put the trim back down. Line it up, drop it down and then shift to see if it is caught.
Old Feb 28, 2010 | 01:26 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Eh?
Old Feb 28, 2010 | 01:41 PM
383vett's Avatar
383vett
Exactly right. The indicator has a horizontal tab that fits into a u shaped groove in the shifter indicator mechanism. Put it near the middle of the console, put the shifter in drive and they should fit. If not, just move the indicator until the tab fits into the groove. Did I just make this more confusing?
Old Feb 28, 2010 | 01:53 PM
TA's Avatar
TA
Look under the center console and it should be pretty self-explanatory
Old Feb 28, 2010 | 03:00 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Old Feb 28, 2010 | 07:46 PM
Joe C's Avatar
Joe C
- it ain't rocket science -
To Shifter indicator
