Trottle body gaskets
Old Mar 1, 2010 | 10:45 AM
1986-z51's Avatar
1986-z51
Default Trottle body gaskets
Need help finding trottle body gaskets. The base gasket I can find. Looking for the coolant/iac housing gasket. Any body got any pt#s on this.1986 coup.
Old Mar 1, 2010 | 01:09 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Napa, Pep Boys or Advance Auto should have one for you, but it may come in a complete throttle body gasket kit. Or you can just cut one out of a sheet of gasket material. Should be pretty simple to make.
Old Mar 1, 2010 | 01:31 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
For my 92 I order a couple of the sets from NAPA when I'm down to one.
They are not cheap but include all the gaskets you could need for the TB.
Old Mar 1, 2010 | 03:35 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
summitracing.com ,,48, 52 or 58mm.
http://www.summitracing.com/search/M...le+body+gasket
Old Mar 1, 2010 | 03:47 PM
ch@0s's Avatar
ch@0s
yup, have to buy the TB kit to get it.
Old Mar 1, 2010 | 06:36 PM
1986-z51's Avatar
1986-z51
Found a trottle body gasket set at Auto zone.Oreillys was lost for some reason.But after trying to remove the coolant/iac housing gave up these bolts are very unquarpitive,did not want to break them,witch is what was going to happen.On the possitive side I did get grind the lip out of the bottom of the plentum opening.
To Trottle body gaskets
