89 horn problems
Old Mar 1, 2010 | 02:31 PM
drayset1010's Avatar
drayset1010
Default 89 horn problems
I bought this car and fixed alot on it now for the little tedis stuff. The horn does not work. The horns them self work but does not work with the wheel. The alarm system looks to be torn apart could that be it if so what can i do to fix this.
Old Mar 1, 2010 | 02:35 PM
Dolfan's Avatar
Dolfan
I had a problem with my 89 coupe back about 5-6 years ago. My horn issue was similar that the horns would sound but no horn from the wheel. I opened up the center cover to the steering wheel and found that mechanism under the cover wasn't able to make contact, I think it had bent to where it wasn't making connection any more.
As I remember I bent and reshaped the metal piece so that it would make good contact upon being pressed and that did it.
I'd check at the wheel, might be the simple fix.
Old Mar 2, 2010 | 07:16 AM
drayset1010
I took the yellow wire and touched it to the ground inside still no joy.
Old Mar 2, 2010 | 07:40 AM
runner140*'s Avatar
runner140*
Does this help?http://forums.corvetteforum.com/c4-t...on-it-own.html
To 89 horn problems
