Super Ram Troubles
Old Mar 2, 2010 | 04:16 PM
splehigh's Avatar
splehigh
Default Super Ram Troubles
Hello,
I recently put a an Accel Super Ram on my 90. It ran great for a a week or two and then started having issues after my buddie checked the fuel pressure at the rail. It has a bad hesitation at low rpms. If you stomp on the pedal it sometimes backfires in the intake.
We replaced the fuel pump and injectors. New plugs and wires. New O2 sensor. Checked for vacuum leaks, couldnt find any. No CEL. No codes.
I'm hoping I dont have to remove the intake and install it again. Wasnt a very fun process.
Any help would be greatly appreciated.
Thanks,
Steve
Old Mar 2, 2010 | 08:26 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Sounds like a fuel pressure issue. What's the reading?
Old Mar 3, 2010 | 06:19 AM
splehigh's Avatar
splehigh
I dont remember exactly what the numbers were, but when I installed the intake I also installed an adjustable fuel pressure reg from TPIS. I set the reg to what TPIS recommended.
I will try to check it again this weekend. What would you recommend setting the pressure at?
Thanks!
Old Mar 3, 2010 | 08:13 AM
bjankuski's Avatar
bjankuski
Do you have a custom tune for the superrram? To me it sounds like you need more tip in fuel programmed into the chip.
Old Mar 3, 2010 | 08:57 AM
fevest's Avatar
fevest
Originally Posted by splehigh
Hello,
Steve
Well since you state it was fine until fuel pressure was checked. I would think you should go over everything involved with that process. As something must have been broken when he checked it. Maybe the valve is messed up.
Old Mar 3, 2010 | 12:52 PM
Calderone's Avatar
Calderone
Old Mar 3, 2010 | 01:17 PM
splehigh's Avatar
splehigh
That is a good point. Is it possible that the schrader valve is restricting fuel flow? It seems highly unlikely. Isnt it similar to a valve stem? One would think that it would be leaking fuel if it was defective since the fuel pump is pushing the fuel into the fuel rail.
I could be wrong though. lol
Old Mar 5, 2010 | 12:15 PM
splehigh's Avatar
splehigh
Bump
Old Mar 5, 2010 | 12:22 PM
bjankuski's Avatar
bjankuski
I did not see an answer to this question? A backfire in the intake indicates that it is lean. Either you have a vacuum leak, an undefined mechanical issue that is causing it to go lean, or the chip needs adjustment.
What is the fuel pressure?
Do you have a custom chip or stock chip?
Did you check for vacuum leaks?
Old Mar 5, 2010 | 12:29 PM
cv67's Avatar
cv67
St. Jude Donor '05
Leave it at the stock setting, what is it with guys wanting to keep cranking the pressure up to the moon, it isnt doing any good at all.
Old Mar 5, 2010 | 12:56 PM
pologreen1's Avatar
pologreen1
I don't know, sounds to me like something is not done right.
I like your stats though, in fact I am surprised you need help with such a simple problem being here so much
splehigh's Profile
Member Since
02-25-2009
Total Posts
4,294,967,295
Posts Per Day: 11,508,290.91
Old Mar 8, 2010 | 07:51 AM
splehigh's Avatar
splehigh
splehigh's Profile
Member Since
02-25-2009
Total Posts
4,294,967,295
Wow! Those stats are way off. I've only been on here a couple times.
Thanks for bringing that to my attention.
Old Mar 8, 2010 | 08:30 AM
splehigh's Avatar
splehigh
The car has never had a custom tune. As far as I know the computer is stock. When I checked the fule pressure it was normal, but I dont remember what the numbers were. I will check it again and post the numbers. Thanks
I know its not cranked way up. Even I know that you can ruin your injectors doing that.
Old Mar 8, 2010 | 09:19 AM
Red 91's Avatar
Red 91
If your fuel pressure is ok, I would suspect a vac. leak. You say it ran well for awile, maybe check all intake bolts and gaskets. Good luck!
Old Mar 8, 2010 | 09:36 AM
bjankuski's Avatar
bjankuski
[QUOTE=splehigh;1573345285]The car has never had a custom tune. As far as I know the computer is stock. When I checked the fule pressure it was normal, but I dont remember what the numbers were. I will check it again and post the numbers. Thanks
You will need a custom tune to fix the problem. The superram requires significant amounts of tip in fuel added to prevent a lean pop on acceleration.
I doubt you have a vacuum leak. The speed density computer system works on intake vacuum and a vacuum leak would show up as a high idle condition but the mixture would still be ok. The added air would be compansated for by the MAP sensor and the air fuel ratio would still be correct. On a MAS air car a vacuum leak could cause a lean pop but the chances are less on a speed density car.
Old Mar 8, 2010 | 09:42 AM
Kool88vette's Avatar
Kool88vette
[QUOTE=bjankuski;1573345833]
You need a custom tune.
Old Mar 8, 2010 | 01:33 PM
splehigh's Avatar
splehigh
Default PCM For Less
Hmmmm... What do you guys think about this?
Quoted from Alvin at PCM For Less:
It is normal for them to have a pumpshot type hesitation but you should
have noticed it right away. Seeing how it is a problem that has shown
up it is likely not something that can be fixed with a tune unless if
you disconnect the battery the problem goes away again.
Alvin@pcmforless.com
PCMforless of NC, INC.
(704) 307-4227
106 Performance Road
Mooresville, NC 28115
On 3/4/2010 9:10 AM, PCMforless Sales wrote:
To Super Ram Troubles
Old Mar 8, 2010 | 06:38 PM
bill mcdonald's Avatar
bill mcdonald
I have ran my built 355 on the stock 90 chip a lot and never had backfires or hesitation.
I smog my 90 on the stock chip everytime. it would not pass on the rollers with this nonsense.
did you guys move the timming when messing with the shrader valve.
discoonect the map sensor?
Old Mar 8, 2010 | 08:19 PM
Vincentiroc's Avatar
Vincentiroc
I have a Super Ram on my 90 IROC. You did everything but check the fuel filter. Take it off and try blowing through it.
Old Mar 8, 2010 | 11:18 PM
Swift_Striker's Avatar
Swift_Striker
I'm also voting for timing, it can be bitch
