1st Vette and clueless
Old Mar 10, 2002 | 01:44 AM
szukrider's Avatar
szukrider
Default 1st Vette and clueless
I here all this talk about codes, could someone please tell me how do you get these codes from your car. I really don't have a clue......sorry
Old Mar 10, 2002 | 02:14 AM
A's Avatar
A
Default Re: 1st Vette and clueless (szukrider)
On the underside of the dash near your right knee, there is a connector called an ALDL (that stands for assembly line data link) and there are 2 slots on it that you jump together with a paper clip. The check engine light will flash at you. It will flash each code 3 times. The first set of flashes is the 10's digit and the 2nd set of flashes is the ones digit. So if it flashed <flash> <flash> <flash> <slight pause> <flash> <flash> <flash> <flash> that would be code 34 (3 flashes then 4 flashes) and it would repeat that code twice more. It starts out by flashing code 12 I think and that just means it's going to start giving you the codes. It loops continuously so when it flashes code 12, you know it's starting over. You can later reference the codes to see what they mean.
I forget what ones you jump though but I'm sure someone here will tell you.
BTW Welcome aboard :seeya
[Modified by A, 12:16 AM 3/10/2002]
Old Mar 10, 2002 | 02:21 AM
scorp508's Avatar
scorp508
Do you mean computer trouble codes, or RPO codes that tell you what options came on your car originally?
For RPO codes, look on the underside of your center console. If they are not there, they will be on the underside of the storage bin behind the driver's seat. They are all 3 character combos of letters and numbers. :)
Old Mar 10, 2002 | 04:10 AM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Default Re: 1st Vette and clueless (A)
On an 86 you jump the two pins in the upper right had corner of the ALDL unit.
Old Mar 11, 2002 | 12:25 AM
szukrider's Avatar
szukrider
Thanks my friend....
Old Mar 11, 2002 | 12:27 AM
szukrider's Avatar
szukrider
Default Re: 1st Vette and clueless (Husker Vette)
Thanks a 1,000,000
Old Mar 11, 2002 | 12:37 AM
JonM's Avatar
JonM
RPO Codes- http://www.netspeed.com.au/corvette/Vettestuff3.html
Just to get you started
Trouble Codes- http://www.fiero.mn.org/Knowledge/Features/ECMcodes.htm
Old Mar 11, 2002 | 12:41 AM
BBA's Avatar
BBA
Default Re: 1st Vette and clueless (JonM)
Here is THE trouble code and diagnostic website:
http://www.batauto.com/Gm.html
BAT Auto Tech
:flag
[Modified by BBA, 11:49 PM 3/10/2002]
To 1st Vette and clueless
