Control Arm Bushings
Old Mar 10, 2010 | 09:50 PM
kirby-57's Avatar
kirby-57
Cruising
I tried to tell them that the poly bushing should not turn in the link it should rotate on center metal bushing to work properly.
Old Mar 10, 2010 | 11:39 PM
falconxls's Avatar
falconxls
Good information. Thanks for all the input. I thought of cutting a small grove between the two bushings where they meet when installed and drill a hole in the center of the arm for th zerk. This would allow the grease to enter past the bushing and coat the metal sleeve.
Mike
Old Mar 11, 2010 | 10:25 AM
Aardwolf's Avatar
Aardwolf
Originally Posted by aboatguy
But you are greasing the surface that is not supposed to move....
I guess I'm not understanding what he did. The ID of the bearing moves right? So you drill a hole through the bushing where the zerk is. That way grease goes down to where the bushing rotates. I have not done this yet on mine. I'm thinking of using heim links in the rear and those delalum bushings for the arms. I have read that your grease gun needs to be decent to push the thick grease in there.
