sensor??
Old Mar 6, 2010 | 03:45 PM
lexman52's Avatar
lexman52
Default sensor??
Ok guys, i just broke a green wire on some sort of sensor on the block right between the 2 spark plugs on the drivers side closest to the front of car. Of course it broke right at the plug so i cannot splice it. What sensor is it. I will just need the wire with plug to go into the sensor.Any idea where i can get one.
Old Mar 6, 2010 | 04:13 PM
engle1147's Avatar
engle1147
If it is a single green wire then that's the wire that should go to cluster for the engine coolant temp gauge but I don't recall it located between 1 & 3 thought it was between 6 & 8.....but it maybe correct for your year model.....no worries though the ECM gets its coolant temp from another sensor in the front of the car's intake.
Not sure where to tell you to go to get a replacement connector though.
Old Mar 7, 2010 | 08:15 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's a temp switch for the booster fan, mounted to front side of rad.
The connector is the same one used on the knock sensor, so your local parts place has 2 chances to find you the correct connector.
Here is a pic of my spare, so you can show them.
Old Mar 7, 2010 | 09:13 AM
lexman52's Avatar
lexman52
sorry but its on the other side of motor. green with white strip. Coming out of the block. Same type of plug thou.
Old Mar 7, 2010 | 09:48 AM
AGENT 86's Avatar
AGENT 86
I'm confused, you said it was drivers side. So now it's on passenger side ??
Old Mar 7, 2010 | 11:18 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Agent, he is responding to Engle's comment that his is on the right side....
The wire is as Agent 86 states, between #1 and #3, and is for your cooling fan in front of the radiator.
Old Mar 7, 2010 | 11:37 AM
engle1147's Avatar
engle1147
Sorry for the confusion.
Old Mar 7, 2010 | 12:05 PM
lexman52's Avatar
lexman52
I don't mean to be a jurk but the green wire with a white stripe that i'm talking about is on the drivers side between the 2 spark plugs. It goes to a relay next to the battery. There is a solid green wire that goes to the fan motor from the radiator just below the cap. Steve
Old Mar 7, 2010 | 12:53 PM
coupeguy2001
go to car qwest. they have all of them
Old Mar 7, 2010 | 02:42 PM
lexman52's Avatar
lexman52
This is where it is
Old Mar 7, 2010 | 05:27 PM
rodj's Avatar
rodj
That is the low coolant sensor; wire goes into main harness by the fan , not to the fan
On my '87 at least ; the wire from the head sensor you mention goes to the Aux fan relay mounted on the front of the radiator shroud (by the LH hood hinge) .Relay by battery is for main fan
To sensor??
