E85, PT91.5 mm , 1000 + setup
Old Mar 6, 2010 | 07:18 PM
red L98's Avatar
red L98
Default E85, PT91.5 mm , 1000 + setup
sup guys ,
some of u know my car or atleast saw some threads about it . i picked up a Pt 91.5 mm turbo with a 1.00 A/R G trim .The motor this turbo is going on is a 434 sbc with a nice set of 18 degree heads that flow over 360 CFM , it's not gonna be an EFI setup , im gonna run a blow threw carb and E85 as fuel . the car has a 2 speed power glide and solid axle rearend . i wanna stay away from the Air to water intercooler and try to find a Air to Air setup that can take 1000+ HP
Old Mar 6, 2010 | 09:55 PM
mnstrlt1's Avatar
mnstrlt1
Originally Posted by red L98
sup guys ,
Sounds like a serious setup. share the details, I haven't seen your c4 before?
Old Mar 6, 2010 | 10:43 PM
red L98's Avatar
red L98
Old Mar 7, 2010 | 10:06 PM
mnstrlt1's Avatar
mnstrlt1
I take that back, I have seen this vette before! I thought i saw this car up for sale some months ago?
Regardless, sounds (and looks) like an awesome build!
Old Mar 8, 2010 | 04:12 AM
93VettePilot's Avatar
93VettePilot
That a really nice setup. No matter what intercooler you use you are going to lose alot of cfm. You might be better off with a methanol/water injection system and no intercooler. Looks like you have one hell of a fuel system.
Old Mar 8, 2010 | 07:24 AM
red L98's Avatar
red L98
yeah i had it up for sale this summer , i'm in med school and dont have much time for it .. my friend is gonna be doing most of the work on it for me this time .. i did most of the work on this car , it's time to let someone else step in and help
Old Mar 8, 2010 | 07:26 AM
red L98's Avatar
red L98
running E85 should help cool things up , but i still need to run a intercooler , i plan on running 25lbs of boost
Old Mar 8, 2010 | 02:01 PM
RC000E's Avatar
RC000E
Yeah, EGT's on E85 are a solid 200 degrees cooler. I ran an E85 turbo'd car for three years but sold it last year. I street drove the car. Full load, full boost I saw 1250F max. Huge jump in torque and reduced spool time nearly 1000rpm. Tuning it was pretty straightforward, just a little pissy at light loads/lean conditions that gasoline generally tolerated. E85 definitely likes a little richer lambda for max power vs gasoline on boosted cars. Best part of E85 is no burnin eyes if your idling in a closed area, plus it deepened the tone of the car.
I built an Integra 2.0liter that made 890whp on 36psi with Borg Warner S372/divided t4 housing. I used a 4" thick 30" wide 12" tall intercooler air/air bar/plate with 3" piping...no problems...tuned on C16. Of course those chambers are pentroof and less detonation prone, but if an Integra can do it, your sh*t sure can.
May be some limited pressure drop, but if you match the proper core to the cfm support you need, charge density and IAT drops are a win in my book. Plus you make the system less complex, which means better reliability.
Old Mar 8, 2010 | 04:01 PM
red L98's Avatar
red L98
Good stuff. i'm lost on the intercooler , not sure what to pick .. i found a core that would work great on the vette and they claim in can support 1300HP with 2 psi drop .. it's a vertical flow , with 3inch inlet 3inch center outlet, the core seems small for the HP rate . the core was 25x9xx3.5 with no ends just the core . u think it would work ??
Old Mar 8, 2010 | 08:25 PM
RC000E's Avatar
RC000E
Well, one difference to point out is I made that power on a horizontal core, your looking at a vertical flow core over a much smaller distance, so that in itself is a plus. That core your looking at is pretty big, and frontal area is adequate based on what I've built and seen built.
Really, it just comes down to designing the endtanks properly and ensuring adequate airflow across the core. I think you'll be fine with that. I'm not sure what your intentions are, but some type of V mount might be a good idea. You don't want hot intercooler air bleeding onto the rad and increasing engine temps.
Old Mar 8, 2010 | 09:45 PM
red L98's Avatar
red L98
yeah a V mount is what i plan on doing .. the one thing i did not like was that this intercooler has cast endtanks ... cast = heat soak
Old Mar 8, 2010 | 09:47 PM
RC000E's Avatar
RC000E
Yeah, I'd definitely not be about cast either....no way. Cast is the basis of a lot of the ching chong intercoolers on the market. I've used them before, but only on budget stuff. I'd never use it otherwise.
Old Mar 8, 2010 | 09:51 PM
red L98's Avatar
red L98
who can make a nice custom intercooler that can take my HP goals ..
Old Mar 8, 2010 | 10:09 PM
RC000E's Avatar
RC000E
Well, if I were near you I'd be hangin out and building that bitch right on your car. Even though your a carb guy, I'd be able to get over it and forgive you...lol.
The real issue is just making it fit your needs and space requirements. Is the design you need pretty basic or do the tanks need to be pretty specifically fit to your application? You don't want simple endtanks if it leads to heavy turns, which lead to pumping losses...know what i mean. Guess it depends how difficult it'll be and how specific your instructions are. I know lots of capable guys.
Old Mar 9, 2010 | 05:33 PM
red L98's Avatar
red L98
nothing crazy just ur basic setup with center outlet and pass inlet .. i'm prob just gonna end up building one myself ... change of plans i'm gonna use my FAST EFI system .. they want 1700$ for the blow threw carb that i want
Old Mar 9, 2010 | 09:06 PM
RC000E's Avatar
RC000E
Now your alright in my book...lol. Make sure you have enough fuel system for the E85. You gonna have to convert your car to high pressure now, or isn't it all built yet?
Old Mar 9, 2010 | 11:26 PM
AKS Racing's Avatar
AKS Racing
www.extremeintercoolers.com
JR Perot is the owner and a very cool guy. He has built numerous high-end IC for my stuff (including one for a custom 3 lobe rotary in airplane). My last IC he built went well past 1000WHP and I was running just over 25 psi at the manifold.
Tell him Aaron (with the vettes) from TX sent you.
To E85, PT91.5 mm , 1000 + setup
Old Mar 10, 2010 | 07:13 PM
red L98's Avatar
red L98
lol...the car fuel system was built for EFI , i think with E85 i have to step everything up about 30% ... not sure but ill look into it
Old Mar 10, 2010 | 07:14 PM
red L98's Avatar
red L98
Thanks man
Old Mar 10, 2010 | 08:26 PM
Bowtie8's Avatar
Bowtie8
Thanks man
I had Precision build my intercooler.
mounts in front of Radiator.
4.5" core
1300HP rated.
BTW, I have my 434 out. heads off, found broken inner valve spring.
I am not very happy about this, I dont know how long I have been running it like this. Pistons look OK,
I got the Heads over at Morans he is going to go thru them, and set up new springs for tubo cam
I'm probably 2 months from Dyno, Its taken a while but getting there.
pair of 6252 Precision air to air into Miniram 434, on pump gas.
JW
