3rd time is the charm
Old Mar 7, 2010 | 07:49 PM
jakes87vette's Avatar
jakes87vette
Default 3rd time is the charm
Car 87 with 128 heads stock cam
So I installed Self aligning 1.6 RR. At 5000 RPM it is making a rattling noise. I had not removed the guide plates because it appeared that there would be no clearance issues. After reading other post I decide it was the GP making the noise so off come the valve covers again and out come the GP's there was no abnormal wear and pushrods were perfect. Reassemble and still making the noise. Now I'm going to do the springs and valve seals and this better be the last damn time I have to take this crap apart. I've decided to go with Comp 981 springs. A Few ? what valve locks do I need there are a lot of different kinds and I cant find the answer in my manuals. Just a part # from Summit would be good. Also could use some good instructions/ advice from those that have removed the exhaust rotators and installed shims. Some shim part #s would also be helpful. I noticed in the manual the exhaust and intake installed spring height are different. That sound right? Thanks.
Old Mar 7, 2010 | 08:21 PM
John A. Marker's Avatar
John A. Marker
Did you look at the underside of your valve covers? Could the springs you have on be so weak for your lift that when you are hitting 5000 RPM they are letting the RR go higher than normal? Check for marks on the inside of the cover. It would more than likely be the exhaust valves since they normally have a higher lift than the intake.
Old Mar 7, 2010 | 09:22 PM
ch@0s's Avatar
ch@0s
when I put RR on mine I had to go with stamped steel Valve covers the Mags were hitting the RRs.
Old Mar 7, 2010 | 10:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
It's likely that you need to grind down the drip tabs a bit and narrow the VC bolt bosses.
The 981s will work well, use the OEM retainers with new keepers. Also, install new OEM valve seals.
Old Mar 7, 2010 | 11:36 PM
jakes87vette
do i need 7 degree or 10 degree locks
Old Mar 8, 2010 | 08:25 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Do you remember this post, from your other thread.
http://forums.corvetteforum.com/1573141111-post6.html
You cannot use SA rockers with hardened guide plates.
To 3rd time is the charm
