D36 gears
Old Mar 7, 2010 | 08:07 PM
2outlaw1993's Avatar
2outlaw1993
Default D36 gears
Ok i have a 93 auto vett and im switching from 2:59 gears to a 3:54... i am already in the process and have the rear end off the car..someone told me that if you have a auto that you need to do a D44 swap? just because its stronger and that the D36 will not hold up...i run on the strip a lot and the last thing i would want is to have to replace a rear end...does anyone else run gears this low on a D36? if so have you ran into any problems?
Old Mar 11, 2010 | 10:57 PM
champ's Avatar
champ
I have the 3.54 gear in my 94 auto D36 now for over 6 years. As long as you run street tires at the track, I think you will be fine. These gears really woke the car up!
Old Mar 12, 2010 | 05:11 AM
rodj's Avatar
rodj
http://forums.corvetteforum.com/c4-t...ic-limits.html
Old Mar 12, 2010 | 06:58 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
i run 3.73s in my d36 on street tires at the track,what kind of mods do you have?
Old Mar 12, 2010 | 07:58 AM
PDQUIK95's Avatar
PDQUIK95
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
Jacob,
A Dana 36 with 3.54 gears in an auto should be fine behind a fairly stock 275-300RWHP application even with DRs provided the gear is set up right and you don't try to run too much stall in the convertor. High stall speeds >3000 can have the same effect as higher horsepower engines at launch putting more strain on the rear. 60' times in the 1.7 to 1.8 should be a safe range. It's when you start seeing 1.6x and lower 60' times that you will start pushing the max limits of the D36.You should also make sure you have an maintain a good clutch pack in the gears if you drag race alot.Worn clutches can cause increased wear on spider/side gears causing breakage problems as well.If you plan for more power later though as most all of us usually do and it's in the budget,the D44 would obviously be the better way to go.
I did manage to run a 3.54/D36 behind a 383/375RWHP set up w/2600 stall and Drs for 3 years without issue before switching to a D44/3.73. 60' times were in the 1.65 range and that's with about 120 passes from counting time slips.
Rick
Old Mar 12, 2010 | 10:28 AM
jhammons01's Avatar
jhammons01
go back and slap "someone" for telling you bad info..........
Old Mar 12, 2010 | 02:49 PM
2outlaw1993
Default dana36
well i have the 354s in and they run great..all iv done to the car is exhaust and cold air nothing major...yet now im just having problems with the speedometer but ill figure that out...thanks for all the help
Old Mar 12, 2010 | 02:52 PM
2outlaw1993
i also was wondering if theres like any little mods that can help horse power with damaging mpg too much...any ideas?
Old Mar 12, 2010 | 11:25 PM
856SPEED's Avatar
856SPEED
running 3.73's with a ZF six speed putting down roughly 360rwhp with street tires for many years......had the rear end rebuilt when we did the gear swap......no problems at all.........
To D36 gears
