Cruise Controll?
Old Mar 9, 2010 | 08:57 PM
glassman74's Avatar
glassman74
Default Cruise Controll?
Just got my 92 and it doesn't work. Where do I start?
Thanks glassman74
Old Mar 9, 2010 | 09:38 PM
Harsh20's Avatar
Harsh20
inspect the diaphragm under the hood to see if it is busted. you can trace the cable back from the throttle body to find it. then the check the fuse for the cc. then the switch itself.
Old Mar 9, 2010 | 10:03 PM
Churchkey's Avatar
Churchkey
The simple things first.
Speedometer working properly?
Check the mechanical linkage, pull the lever @ the cruise servo to insure it operates the throttle.
Engine running: remove the large vacuum hose from the cruise servo & check for vacuum. No vacuum = fix that problem.
If it has vacuum: shut off engine, use a mighty vac to pull vacuum on the servo this will test the integrity of the servo & the pedal switch(s)
Will not hold vacuum=repair the faulty component.
Holds vacuum = electrical system.
Check the fuse.
If all of the above checks ok you need a FSM to check the electrical.
A word of caution when following the FSM.
Check the servo electrical first.
Skip the step about checking for power @ the cruise module, save it for last.
After checking the servo if ok go to the steering colum connector to check for power & switch operation.
Old Mar 9, 2010 | 10:24 PM
surfer92's Avatar
surfer92
Check the fuse.
You did check the fuses??
1) Check the hose coming from the engine for vacuum.
2) Check hose going to brake pedal.
3) check release valve on pedal, sometimes it leaks.
4) Check CC for power.
5) check switch on stalk.
Right near the battery, is where both my hoses gave way, guessing the battery fumes did them in.
Old Mar 9, 2010 | 10:30 PM
pcolt94's Avatar
pcolt94
The last few cruise problems we diagnosed on the Forum (including mine) turned out to be the electrical switch on the brake pedal. If the vacuum check valve is bad it will probably affect the A/C vents from working correctly.
But if the check valve is OK, then the switch is a likely prospect.
If you have a clutch, it has a switch to.
Also check the fuse and the switch on the turn signal.
Check these links for additional information.
http://forums.corvetteforum.com/c4-t...-question.html
http://forums.corvetteforum.com/c4-t...-for-94-a.html
Old Mar 10, 2010 | 09:59 AM
Flame Red's Avatar
Flame Red
This should help:
http://www.corvettefever.com/howto/82001/index.html
Old Mar 10, 2010 | 01:12 PM
pcolt94's Avatar
pcolt94
Let me give a quick over view of the reality of actual problems. From what I have done, seen and heard, the major components are not on the top of the list of defective parts. The cruise control module under the right side of the dash is a real convenient point to make measurements from but is a bear to get to.
The solenoids in the servos can be checked with resistance to see if their open. It's a basic check only. Operation of solenoid cannot be verified using this check.
Most of the actual problems have been bad vacuum hoses or connections, the check valve, electrical connections or the dis-engage switches on the brake (or clutch). The switch on the brake is a triple switch that has the cruise switch in it as well as the brake light and lock-up (TTC) switch.
The switch can be removed, taken apart and contacts cleaned if corroded. The contacts also come out of the switch body, it's beautiful. Save you $50 if you had to buy one.
But most of the time the problem may seem difficult, but the cure is simple.
If the problem can't be found simply or by poking around, then selected points have to be monitored (taking measurements) as the car is driven and evaluate the results. Actually have to troubleshoot it as I did for mine.
Old Mar 10, 2010 | 01:24 PM
surfer92's Avatar
surfer92
CC module on a 92 is right beside the ECM, very easy to get to and it is most llikely a vacuum hose, both my 92 and 93 had issues w/hoses.
Old Mar 10, 2010 | 02:48 PM
pcolt94's Avatar
pcolt94
I will consider myself as “corrected” as far as the location on the CC module. I just assumed the 92-93 was the same as my 94 which is really buried up under there. If interested, take a look at my second link above to get an idea. Darn thing is under the SIR module, a mess to get out.
To Cruise Controll?
