Anti-Lock
Old Mar 12, 2010 | 01:12 AM
Alfs86's Avatar
Alfs86
Default Anti-Lock
On my '86, I just had a light show up on my center info panel that reads
"Anti-Lock". I haven't done any type of work on the brakes or wheels. Anybody have any idea what this is about? I'd appreciate any help. Thx
Old Mar 12, 2010 | 07:20 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
The light simply means that your ABS unit has been removed from the loop electronically for some reason. You'll have to have someone pull the code to figure out where to start, then follow the diag. steps to figure out what is actually wrong. Most of the time it is a wheel speed sensor or tone ring problem (dirty sensor, rusty ring), but it could be the ABS unit itself. Right now your foundation brakes should function normally, but if you get into a skid your ABS will not activate to pulse the brakes.
Old Mar 12, 2010 | 11:00 AM
Alfs86's Avatar
Alfs86
Thats what I like about this forumn: the willingness to provide excellent information such as found in this reply. Thank You!
Alf
Old Mar 12, 2010 | 02:56 PM
engle1147's Avatar
engle1147
Could be as simple as the wire on the brake booster has been disconnected or debris on one or more of the wheel pickup sensors.
Old Mar 12, 2010 | 03:13 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/ABS%20Electrical.pdf
http://members.shaw.ca/dankai/ABS.pdf
To Anti-Lock
