Braided SS Brake Lines?
Old Mar 15, 2010 | 12:06 PM
techvette's Avatar
techvette
Default Braided SS Brake Lines?
Anybody have a good source on where to buy these?
Old Mar 15, 2010 | 12:11 PM
pcolt94's Avatar
pcolt94
Tire Rack
I bought the Goodridge lines. Fit well, easy install.
Old Mar 15, 2010 | 12:42 PM
kangi's Avatar
kangi
I just ordered these:
http://www.vbandp.com/detail.aspx?ID=72
Old Mar 15, 2010 | 01:43 PM
Aardwolf's Avatar
Aardwolf
Use the DRM lines. http://204.200.163.238/?p=434
Old Mar 15, 2010 | 01:47 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Can you feel the difference? Was it worth the trouble?
Old Mar 15, 2010 | 01:53 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I dont know if I can feel a difference in the brake pedal, but if you grab your old rubber line and have someone hit the brake pedal, the rubber ones swell quite a bit. Since I race it was good assurance for me to switch to SS.
Old Mar 15, 2010 | 02:07 PM
ggrassmid's Avatar
ggrassmid
I ordered a set from Corvette Central along with other stuff. But it seems $100-$125 is about average price. Though the ones from CC say made in America on them , I think they were $110. But other above have good suggested places too.
Old Mar 15, 2010 | 02:25 PM
mack89vette's Avatar
mack89vette
I think steel braided lines are well worth it.
When I got my 89 vette over a dozen years ago, the stock brakes werent very good,
to say the least. I could tell a difference on the feel with the steel lines.
I later upgraded rotors, pads, and rebuilt all the calipers.
Now my brakes are unbelievable, the expression stopping on a dime is now true.
Good product in the overall brake system package.
Old Mar 15, 2010 | 08:15 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I got my Earls lines from Summit Racing, they have a store close by
Old Mar 15, 2010 | 09:22 PM
aboatguy's Avatar
aboatguy
Originally Posted by Aardwolf
Old Mar 15, 2010 | 09:58 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Just a note: the brake line is still rubber. Its just covered with the pretty stainless steel braid.
Old Mar 15, 2010 | 10:05 PM
mseven's Avatar
mseven
Earl's are teflon core.
Old Mar 15, 2010 | 10:09 PM
aboatguy's Avatar
aboatguy
Sorry MSEVEN I did not see your post when I posted....
However, we are in violent agreement.....
Every stainless line I've seen is lined with teflon....
...and don't expand under pressure like rubber brake lines*
Mike
*While I'm sure the stainless does expand however, I've never seen one visibly expand, whereas, I've seen rubber hoses visibly expand
Old Mar 16, 2010 | 12:35 AM
techvette's Avatar
techvette
Ordered a set earlier today from Mike Yeager at East Coast Performance. Very helpful and gave me a great deal!
Old Mar 16, 2010 | 06:50 AM
aboatguy's Avatar
aboatguy
Since you will already have to bleed your brakes, I suggest you give DRM a call and order a brake BIAS spring for your car.
Mike
Old Mar 16, 2010 | 07:22 AM
Weav's Vet's Avatar
Weav's Vet
Also, if you don't have them already order some Speed Bleeders. It'll make the job a whole lot easier.
Old Mar 16, 2010 | 07:27 AM
Kubs's Avatar
Kubs
I bled my brakes using speed bleeders for the first time this past weekend. WOW! So much simpler!
To Braided SS Brake Lines?
Old Mar 16, 2010 | 07:50 AM
pcolt94's Avatar
pcolt94
Speed bleeders are great. Bought 2 from Napa and a couple more came with my J55 setup. I could never get the things to seal correctly so I always put back in the original bleeder screw valve when I’m done bleeding.
I noticed one day that the original bleeder had a longer thread shank thus allowing it to go deeper into the caliper and contact the seat tightly. Don’t know if anyone has had this situation also. It does not matter to me, I don’t need to bleed that often.
The speed bleeders also work great on my Chevy truck.
Old Mar 16, 2010 | 09:17 AM
samsonb's Avatar
samsonb
I'd get the Earl bleeders over the Speed Bleeders. They look like a better design.
Old Mar 17, 2010 | 02:07 AM
Mekanic's Avatar
Mekanic
the DRM ones look IDENTICAL to the ones from VB&P, only the DRM's are $40 more..
your call lol
