Lt1 408
Old Jun 20, 2010 | 12:17 PM
  #41
MSR's Avatar
MSR
Erik built my 396, quite a few years ago. That engine has been solid through tons of abuse, various cam/head/intake combinations (made 470rw at one point), I tracked it a lot before installing an oil cooler (hit 300 degrees oil temp regularly), etc. The shortblock still doesn't burn any oil or show that it's any worse for wear. I have friends who used Erik for their engines with similar experiences. I highly recommend his work.
-michael
Old Jun 21, 2010 | 05:06 PM
  #42
rickneworleansla's Avatar
rickneworleansla
Good to know, when the time comes. I'm likely going to be looking for something built for a strong shot of nitrous though.
Old Jul 3, 2010 | 01:34 PM
  #43
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
ttt
Old Jul 4, 2010 | 12:11 AM
  #44
dizwiz24's Avatar
dizwiz24
can you make this thing so that it is recommended for nitrous or FI?
At some point, I'll be looking for a strong 383 or as big a motor as I can get, with forced induction on top.
I know it would prob work, and you are just giving conservative advice.
It just seems lately that if you are building something thats NOT FI (or nitrous) its not going to hit the #'s they are making on the C5 or C6 site.
Im tired of reading about guys with stock bottom ends LSx motors + forced induction making 700+ rwhp.
We need options to flatten those guys.
Old Aug 18, 2010 | 10:28 PM
  #45
SonnyinVA's Avatar
SonnyinVA
Hi Guys,
I definately prefer to call it a 409 and my car is wearing 409 badges from an Impala. I think I calculated that it is a 408.6, which to me is a 409 anyway.
I can testify that if it is built right, it will handle FI or a really big shot of nitrous... but it also requires really good parts and a great tune. Be ready to spend some money if you want it to be stout and durable. I ran mine REALLY hard for a few good years on 2 builds, but it needs to be freshened up now.
It didn't require nearly as much clearancing as I thought it was going to, but I also did use a small base circle cam.
See ya,
Sonny
Old Aug 18, 2010 | 11:15 PM
  #46
1985 Corvette's Avatar
1985 Corvette
I'm curious about something and I'm still learning about these engine combos: if you can get 400+ cid from an LTX block with the right crank, wouldn't that be possible with a gen 1 block as well?
If I read that right, I wonder why I read about guys salvaging old 400 blocks out of 70s blazers and Impalas and stroking it out to 406 or more. Couldn't they settle for a much more plentiful LTX block? Again, still learning about engine combinations and what flies and what doesn't.
I saw 396 thrown around so much for LT1 & LT4 stroker builds, I naturally assumed that was the limits of stroking the LT small block.
Old Aug 19, 2010 | 01:59 AM
  #47
99blancoss's Avatar
099blancoss
Former Vendor
You've got to want to make and LTx fast. Its not cheap, the power is made in the heads and getting the right heads and valve-train combo is not inexpensive at all.
Old Aug 25, 2010 | 07:23 PM
  #48
JAKE's Avatar
JAKE
When are you going to post on your website the specifics and details on the 408/409? I was just there and didn't see any of the details I'm interested in.
As starters, is the $4,600 price I saw in an earlier post the short block clearanced and assembled price or is the clearancing and assembly extra? If extra how much?
Do you plan on posting all the clearances, like, piston to wall, bearing, ring end gap, deck heights, etc. or does the assembled short block come with that on a spec sheet?
Jake
Old Sep 19, 2010 | 01:36 AM
  #49
JAKE's Avatar
JAKE
And the answers are . . . .
Jake
Old Sep 20, 2010 | 11:42 PM
  #50
99blancoss's Avatar
099blancoss
Former Vendor
Jake
Sorry Jake been bust and didnt see this:
Yes that price is for the assembled shortblock
HKE does not publish that information and doe not provide a build sheet with it on it either. It not open for discussion and posting it or providing it has proved more trouble than its worth so he does not do it. If you really needed know something and were putting money down then I'm sure I could get you some limited information but it's not something he readily gives out.
Old Sep 21, 2010 | 12:54 AM
  #51
JAKE's Avatar
JAKE
Thanks for that info. However, Dad taught me to "Never Buy a Pig in a Poke".
Jake
Old Sep 21, 2010 | 01:05 AM
  #52
cv67's Avatar
cv67
St. Jude Donor '05
Thats not a bad price considering what youre getting, sounds like decent prep and parts are going into it.
Old Sep 21, 2010 | 01:14 AM
  #53
JAKE's Avatar
JAKE
Originally Posted by 1985 Corvette
I'm curious about something and I'm still learning about these engine combos: if you can get 400+ cid from an LTX block with the right crank, wouldn't that be possible with a gen 1 block as well? If I read that right, I wonder why I read about guys salvaging old 400 blocks out of 70s blazers and Impalas and stroking it out to 406 or more. Couldn't they settle for a much more plentiful LTX block? Again, still learning about engine combinations and what flies and what doesn't.
414 CID is about as big as you can go with a LTx block and that would be with a .060" over-bore, which not all blocks can safely take. 408 is more common calling for only a .030" over-bore.
Sure it's easy to get over 400 CID using a stock GM 400 Gen I block and crank, in fact I did it (415 CID) and installed it in an 86 Vette. The Mini-Ram, exhaust, sensors, etc., all bolted right up.
Installing a Gen I 400+ engine in a car that has a LT1/4 (or vice-versa) is a different matter though since the fuel/ignition/etc., systems are so different. It can be done but call for a lot of work; a lot more than I was willing to under-take.
QA buddy of mine is installing a LS1 in his 89 Vette and has been wrestling with the wiring for over two weeks. He told me this evening he's still short of being half-way done.
Jake
