engine surging at idle
Old Mar 31, 2010 | 06:58 PM
kanerboy's Avatar
kanerboy
Cruising
Default engine surging at idle
hello i have tried everythjng i can think of cap rotor wires plugs iac valve and pump screen and it still wont go away any suggestions?thanks
Old Mar 31, 2010 | 07:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check all vacuum lines for leaks.
Old Mar 31, 2010 | 08:04 PM
kanerboy's Avatar
kanerboy
Cruising
thank you i will try in am
Old Mar 31, 2010 | 08:11 PM
WW7's Avatar
WW7
The way we usuallly check for vacuam leaks is either use a propane torch or carb cleaner and spray it around all the tubes and upper gasket areas with the car running. If the rpms pick up while your spraying the carb cleaner or waving the propane over these areas then you have found your leak..If you have an exhaust leak it could also affect the idle..Let use know what you find...WW
Old Mar 31, 2010 | 10:18 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Also could be the MAF (at least thats what it was on mine)
Old Mar 31, 2010 | 10:24 PM
megtom2's Avatar
megtom2
Our 86 surged from 600-1k rpms at idle. Changed the fuel filter and oxygen sensor at the same time and it stopped surging. Not sure which one did it but one of them did.
Old Apr 1, 2010 | 07:02 AM
kanerboy's Avatar
kanerboy
Cruising
thanks for all the info
Old Apr 1, 2010 | 02:50 PM
kanerboy's Avatar
kanerboy
Cruising
still no luck with my problem will a egr valve that vwont hold vacuum cause this problem? i blocked off vac line so it wouldnt have a leak
To engine surging at idle
