i just got my 91. after the motor gets warm it starts to miss. It only does it at idle an when not under aload. Have done plugs wires map temp sensor .Thanks
Did the car have the problem before you did the "plugs wires map temp sensor" or did you change that stuff to try to fix the problem?
Check for stored trouble codes yet?
I've got a 91 as well and 'had" and idle issue too after it warmed up.
Well the car is running much better.James hit it right on. Idle air control valve.Thanks for the help guys. great site for help.The valve was full of cabon.
