Clutch Replacement
Old Apr 4, 2010 | 06:57 AM
JAbraham03's Avatar
JAbraham03
Default Clutch Replacement
Yesterday I just dropped the trans out of the car and got the pressure plate and clutch out. How do I tell if the fly wheel needs to be replaced? There is a nice shine on the surface, was on the pressure plate too. It looked like the clutch was worn to the rivets. I am replacing the clutch and pressure plate and throw bearing on the fork. I just dont want to do this and find out the flywheel is no good after it is together. The teeth are fine and no nicks on the surface. There was a lot of crud in the bell housing on the bottom. The previous owner never cleaned it out or took care of the car for that matter, it would even run when I got it so clutch was the next step...
On another note, the clutch was not stuck to the pressure plate for the flywheel.
When reasembling is there any grease that I should put on things and preference?
Old Apr 4, 2010 | 08:45 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Take the flywheel to your local machine shop and have it ground. My local auto parts store has a flywheel grinder, $25 was my cost.
Old Apr 4, 2010 | 10:00 AM
HillbillyBill's Avatar
HillbillyBill
Take it and have it resurfaced. Most parts stores that do drums and rotors can do it.
To Clutch Replacement
