ASR System
Old Apr 4, 2010 | 04:01 PM
lucassmith8101's Avatar
lucassmith8101
4th Gear
Default ASR System
When starting my car all appears fine but after driving a while and usually reaching speeds over 50 mph my ASR systems automatically shuts off and says service ASR what could cause this?
Old May 2, 2010 | 01:09 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Two things off the top of my head. Your TPS sensor is going bad. Or your front to rear tires arent the same height. Common thing when going to the track with slicks. The system cant compensate for the difference in height on the tires and your ASR gets triggered.
Old May 3, 2010 | 09:44 AM
Sinistrad's Avatar
Sinistrad
The other thing is if your "BRAKE" light comes on at the same time, make sure your fluid reservoir is topped off. (This should throw a low fluid code from the ABS system, so if you've checked codes and found nothing, nevermind.)
To ASR System
