Please Help Code ?
Old Mar 13, 2002 | 05:05 PM
jims_red_94LT1's Avatar
jims_red_94LT1
Default Please Help Code ?
How do I see if I have an active fault code in my 1994 LTI Coupe ?
I just took out the MAF screen I took it apart and carefully set aside while I removed the screen and carefully put it back together, reinstalled it now it won't start.
Jim
:flag
Old Mar 13, 2002 | 05:24 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Please Help Code ? (jims_red_94LT1)
Make sure you plugged the sensor on the bottom back on.
Old Mar 13, 2002 | 05:32 PM
jims_red_94LT1
Default Re: Please Help Code ? (BAdAzZV8)
Everything is back in place. I didn't touch anything else, just don't understand.
Old Mar 13, 2002 | 05:34 PM
jims_red_94LT1
I need to know how to see/pull any active codes.
Old Mar 13, 2002 | 06:24 PM
David-F's Avatar
David-F
Use a paper clip and jump the 4 to 12 terminals of the ALDL connector(that's the 4th from the left on top and the one right under it) and turn the key on with out starting and watch the speedo and write down the codes 1.1 is CCM, 4.1 are PCM 9.1 ABS/ASR and let us know what you find.
David Fulcher
Old Mar 13, 2002 | 06:27 PM
jims_red_94LT1
Default Re: Please Help Code ? (David-F)
Thanks David I'm going out to do it now.
:flag
Old Mar 13, 2002 | 06:44 PM
jims_red_94LT1
Hey David, jumped the 2 pins and it read
H32
1.
I have no clue what this means do you?
Thanks for the help.
Jim
Old Mar 14, 2002 | 12:02 AM
purple jinx's Avatar
purple jinx
check out http://home.fuse.net/c4/
Old Mar 14, 2002 | 01:01 AM
David-F's Avatar
David-F
If what you had was H32
4.1
Then it's an EGR code and not the cause of the no start you need to take a look at the coil wire there is a chance that during the removal you may have hit it and if it was on it's way out killed it. Do you know if you are getting any spark? justa pull a spark plug wire and lay it down near the spark plug just far enough away that is it has spark you would be able to hear it jump to the plug, check it out and let us know.
David Fulcher
To Please Help Code ?
