help removing coil
Old Apr 5, 2010 | 09:25 PM
vetteguy216's Avatar
vetteguy216
Default help removing coil
I am removing the icm and coil on my lt1 to get them tested and am having trouble removing the coil, icm.
I am on the left bolt of the bracket and I got the outer nut off but the power steering pump reservoir bracket is not giving me enough play in order to remove inner bolt/stud, do I need to take the bracket off of the stud first and if so where are the bolts to do so?
Old Apr 5, 2010 | 09:56 PM
Bill32's Avatar
Bill32
There's another bolt below that on the p/s bracket. IRRC, you can loosen that enough that you can slip the p/s bracket off the stud. It helps if you pull the heaterhoses out of that bracket.
Old Apr 6, 2010 | 08:31 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I cursed GM the first time I did this
Just changed the ICM again hope this one lasts more than 8 - 10 months.
Old Apr 6, 2010 | 12:13 PM
pcolt94's Avatar
pcolt94
Not to be negative. But if you had a dead engine, testing might show up something. But since the engine is running I don’t think a test will show up anything definitive.
I think with the way auto part stores test them, they will show up with some sort of output. But under load and an elevated temperature of what the engine runs at will not be a duplicated condition.
But I wish you the best of luck and await your test results....
Old Apr 6, 2010 | 12:27 PM
Weav's Vet's Avatar
Weav's Vet
They don't seem to be worth a crap anymore do they. I just had to put another one in my '96.
Old Apr 6, 2010 | 03:30 PM
pcolt94's Avatar
pcolt94
I think my original is still OK. However I am sitting on a GM spare at home just in case.
There is nothing like substitution.
Old Apr 6, 2010 | 07:03 PM
corvette95's Avatar
corvette95
If it was GM then it has a 12/12 warranty on it. Plus dont forget the lithium grease.
Old Apr 6, 2010 | 07:13 PM
vetteguy216
Yeah removed the coil and ICM today there was no heat sink left all of it must have burnt up, both coil and icm checked out fine so I put some heat sink on and reinstalled them both.
Old Apr 6, 2010 | 08:33 PM
uxb101's Avatar
uxb101
i keep one in my glovebox
Old Apr 7, 2010 | 11:06 AM
onedef92's Avatar
onedef92
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Don't forget the thermal compound heat transfer grease that comes with the new ICM. If you don't use it, your ICM'll stir-fry itself to death from all that underhood engine heat in short order!
Old Apr 7, 2010 | 11:23 AM
DougSilver's Avatar
DougSilver
When I was trying to address an engine miss (which I know you are trying to find referring to your other thread), one of the things I did was to replace the stock coil with an MSD coil. This did not completely eliminate the miss but the car definitely ran better after the coil swap.
Doug
To help removing coil
