CODE 32?
Old Mar 13, 2002 | 07:54 PM
jims_red_94LT1's Avatar
jims_red_94LT1
Default CODE 32?
Previous thread
________________________________________ ______________________
How do I see if I have an active fault code in my 1994 LTI Coupe ?
I just took out the MAF screen I took it apart and carefully set aside while I removed the screen and carefully put it back together, reinstalled it now it won't start.
Well I pulled the code and this is what I got.
H32
1.
Never done this before any ideas what could be the problem?
Thanks for any advice.
Jim
:flag
Old Mar 13, 2002 | 07:56 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Default Re: CODE 32? (jims_red_94LT1)
code 32 is the EGR
The most common cause of this code is a bad or intermittent EGR switch which is located on the EGR pipe between the exhaust manifold and the intake manifold. Replace this switch first when you get this code. Next, check electrical connections at EGR valve solenoid and then the ECM. Check all vacuum lines for leaks especially around the EGR valve. Possible ECM failure.
Old Mar 13, 2002 | 08:00 PM
jims_red_94LT1
Default Re: CODE 32? (Jeffvette)
I just don't understand it ran fine before I touched the mAF and now it won't start. I had to of touched something although as careful as I was being I don't see how.
Jim
Old Mar 14, 2002 | 04:42 AM
Jeffvette's Avatar
Jeffvette
Try deleting the history then running it and seeing if it comes back again.
Old Mar 14, 2002 | 09:25 AM
jims_red_94LT1
Can you please explain how to delete the history?
Thanks I appreciate the help.
Jim
Old Mar 14, 2002 | 09:51 AM
Goody's Avatar
Goody
Remove negative battery cable for about 15-30 seconds.
Old Mar 14, 2002 | 10:15 AM
jims_red_94LT1
Default Re: CODE 32? (Goody)
Thanks Goody, I'll try it this evening when I get home. Any other suggestions on what could be causing it not to start? Is the active code keep it from starting?
Thanks for the help.
Jim
Old Mar 14, 2002 | 01:34 PM
jims_red_94LT1
Does anyone else have any idea why it won't start, it sounded like it wasn't getting any spark, will test tonight. Any ideas are appreciated.
Jim
To CODE 32?
