Fan Trouble?
Old Apr 8, 2010 | 02:14 AM
Alex2205's Avatar
Alex2205
Default Fan Trouble?
I always enjoy reading the thread messages. I have a problem with my 1991 corvette, L98 coupe (350 TPI), I have noticed that when the car reaches a 218 TEMP the primary fans start running, the only problem is it won't recycle it stays on all the time. The secondary fan only comes on after I turn on the air conditioning unit. I have taking the vette to the dealer, and the problem still there, many parts where change such as Thermostat, fans relay, Coolant Temperture sensor and refurbished ECM. Can anybody help me solve this mystery? I just can figure it out.
Alex
Old Apr 8, 2010 | 08:59 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Is this a new problem or a problem that came with the vette ?
Has anyone checked to see if there is an aftermarket temp switch, tied into the circuit ?
I don't have a schematic for your year, but you would think the dealer would and would be able to track down the source of power/ground.
Old Apr 8, 2010 | 11:00 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Does it have an aftermarket chip or has the ECM been reprogrammed?
Old Apr 8, 2010 | 11:09 PM
Alex2205's Avatar
Alex2205
Yes, this is a problem came with the car when I bought. The ECM was reprogram by the dealer and an after market chip (Hypertech), and a new MEM CAL was installed by the dealer, from the old ECM but the problem of the fan staying on existed when I purchased the Vette and way before the ECM when Bad. I will trace the wires and look for an aftermarket switch installation. Do you think the aftermarket chip could be the problem?
Old Apr 10, 2010 | 10:30 PM
Alex2205's Avatar
Alex2205
I rechecked the fan relays for any aftermarket switched I use the FSM to track the wiring no switch found..does anybody have this problem before..please help.
Old Apr 11, 2010 | 08:56 AM
AGENT 86's Avatar
AGENT 86
Can you scan and post the electrical schematic from your FSM ?
Have you determined that a ground is being supplied to relay, and your sure the ECM is supplying it ?
Old Apr 11, 2010 | 12:44 PM
gbrtng's Avatar
gbrtng
There's some hysteresis in the fan logic - primary fan on at 218 and off at 208 (? not sure of the temperature). Does the temperature gauge drop while the fan is running? If not, it probably won't shut off until you go over 35 mph or so - its operation is related to vehicle speed also. There are probably other fan logic input / output parameters I don't know about too. Oh, both fans should run when the AC compressor is engaged.
And yes, the ECM grounds the relay coil circuits to actuate each fan.
To Fan Trouble?
