gunned it now dead?
Old Apr 11, 2010 | 12:01 AM
maverick1453's Avatar
maverick1453
Default gunned it now dead?
so my 93 stock vette was running fine nothing wrong
but today i was on the freeway . gunned it to about 100 round there somewhere.
and now its still runs fine but when I stop at a stop light or even once at a stop sign it just strait dies.
i have to start it again and when im at stop sign that it doesnt die or a light. it idles all crazy up and down sometimes normal sometimes the idle is all over the place, everything was fine till i gunned it now i hav no idea wat i did????
any help. oh and i usually only gunn it once every month if that do i hit 100
Old Apr 11, 2010 | 12:13 AM
RED-85-Z51's Avatar
RED-85-Z51
Possibly sucked in an intake gasket? Maybe timing jumped?
Need more info...does it throw any codes? Any odd noises or smells?
Old Apr 11, 2010 | 01:46 AM
383vett's Avatar
383vett
How high was it revving when you hit 100? Did the tranny downshift? Were you near the redline? 100mph is not really that fast. Maybe you broke a valvespring or???
Old Apr 11, 2010 | 02:03 AM
maverick1453
i didnt rev that hi. but now at any stop it like gives itself gas and power and tries to pull when im on the brake. its wierd. then i was actually driving. just coasting not hitting the gas and it died shut off but i just kept rolling in drive
Old Apr 11, 2010 | 02:10 AM
maverick1453
and i thought i smeltsomething funny but then i got out and smelled again and it really wasnt anything.
but i rarely go past 80 and i just stayed on till 100. so im thinking some throttle thing? or timing?
Old Apr 11, 2010 | 04:40 AM
car5car's Avatar
car5car
dirty throat, bad cable, idle speed motor. clean throat, check cable, remove clean idle speed motor.
Old Apr 11, 2010 | 04:49 AM
surfer92's Avatar
surfer92
How much did you have to drink!!
Pull codes, if you smelled something, check under hood for burnt wires.
If it runs fine while revving the engine, most likely it is a sensor or a leaking injector(s).
Old Apr 11, 2010 | 07:51 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
check the MAF
Old Apr 11, 2010 | 11:47 PM
94vettelover2's Avatar
94vettelover2
I gun mine multiple times each & everytime I drive itIf it can't handle WOT often,I will find a car that will.So far,corvettes & the 98 z28(ls1) that I've owned take it no problem & enjoy it
Old Apr 12, 2010 | 12:38 AM
maverick1453
94 vette lover
wat the hell does ure reply have to do with my thread. ure talking to hear ureself talk.
i could give two !@#$@
Old Apr 12, 2010 | 01:48 AM
ZD1's Avatar
ZD1
Well the. Real answer is that you have an older car that has never been pushed; or at least on a regular basis. So you either 1) moved some gunk around messing with your iac or sensor or 2) ran it rich (engine load over 90% is not limited to 14.7 afr) which coated sensors or slightly fouled ur plugs.
Here's my list.
-Spark plugs ($3-4 Bosch ) replace as u were probably due
- iac remove and clean or spray brake/Carb cleaner in the idle circuit in the Tbilisi
- fouled o2 sensor let the ecm give it lean conditions to knock the carbon off
- check for vacuum leaks
- the smell was probably excess fuel, is the vacuum lines to the fpr okay?cracks?
Like most people have said, a 100 mph isn't much...so it is more likely that the car needs to be driven!
Old Apr 12, 2010 | 09:01 AM
j-vette's Avatar
j-vette
St. Jude Donor '10
94 vette lover
Old Apr 12, 2010 | 11:16 AM
94vettelover2
94 vette lover
Just thought I'd chime in.Don't care to hear myself talk let alone hear myself write.If your going to be a d-ck at least learn how to spellHow the hell(ureself)?Beverly Hillbilly?Good luck with your car & spelling
Old Apr 12, 2010 | 02:51 PM
maverick1453
again with u i could give two *$#*@$ how i spell. and yeah hillbillys dont reside in cali chief bye!!!!!!!!!!!!!!1
Old Apr 12, 2010 | 07:27 PM
azrocketman's Avatar
azrocketman
Here's my list.
I'd second checking for any codes. Also add checking the air filter and PCV valve to the list.
Steve
Old Apr 12, 2010 | 07:52 PM
Craq's Avatar
Craq
Originally Posted by kenv
check the MAF
That would be my first guess...
...and OP, please learn to speak in the King's good English...
Old Apr 12, 2010 | 08:02 PM
HONDOBUCK's Avatar
HONDOBUCK
Im not starting anything but what about the Beverly Hillbillys???? They live in cali
Old Apr 12, 2010 | 08:48 PM
Hideki's Avatar
Hideki
When I first got my C4 it had trouble starting and would idle really rough (and almost die sometimes) the previous owner never really drove the car and it sat most of its life. I replaced the fuel filter, PCV valve, cleaned my throttlebody, and ran a bottle of Techron through a tank of gas. The car starts fine and idles great after that.
To gunned it now dead?
