What is this on the engine? Doesn't belong?
Old Apr 11, 2010 | 06:48 PM
my86corvette's Avatar
my86corvette
Default What is this on the engine? Doesn't belong?
I just got this car recently and it's obviously had a hard life. I found this thing on the engine and I don't really think it belongs. I've search the manuals and I can't find it.
This in on the driver's side just below the plenum near the throttle body. It was tucked in there a bit. I pulled it out and found it has 2 small vacuum ports (1 was connected to the EGR and the other to a port coming out the side under the front driver's side of the plenum. On the opposite side of this gadget is a medium sized vacuum port that wasn't connected. I could not find a vacuum line laying anywhere. On the side of the gadget is a 2 wire connector. It was sort of plugged in. I say sort of because the connector won't plug in (it doesn't mate up). Any ideas out there? Below is a pic of how I found it.
Here it is out. You can see the electrical connector doesn't look like it belongs.
There's a mounting tab but I don't see anywhere it's supposed to be.
Here's a side shot.
Another side shot.
Any ideas? Please help. I can't find any pics of engines with this in there.
Old Apr 11, 2010 | 07:19 PM
MotorCity_87_C4's Avatar
MotorCity_87_C4
Looks like the EGR control solenoid.
Old Apr 11, 2010 | 07:25 PM
John A. Marker's Avatar
John A. Marker
I think it is the EGR solenoid and should be located on the passengers side at the rear of the block.
There may be a difference between my 86 and your 86 in the size and shape of the solenoid. Check the passenger side back by the distributor and see if you find this unit.
Old Apr 11, 2010 | 07:27 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
The solenoid is usually mounted to thermostat housing and supply vacuum comes from a nipple on bottom of throttle body (drivers side).
Old Apr 11, 2010 | 07:28 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sounds like someone forgot to put it back in last time the runners were off and stuffed it in there to avoid the hassle.
Old Apr 11, 2010 | 07:36 PM
floridamale's Avatar
floridamale
I wonder if this is a replacement for the OEM part that is no longer made
Old Apr 11, 2010 | 07:39 PM
John A. Marker
Default Look what I found...
Picture is from Autozone.....86 Corvette EGR solenoid. Looks pretty close to what you have.
See one of these around? Agent86 usually knows his stuff....there are differences between my 85 and your 86....is if he said check the thermostat housing...start there.
Old Apr 11, 2010 | 07:43 PM
floridamale
That is the right one but you can't buy that any longer
Old Apr 11, 2010 | 08:04 PM
John A. Marker
Are you sure it can't be purchased? It was on the Autozone web site 30 minutes ago.
Old Apr 11, 2010 | 08:08 PM
my86corvette
I was thinking it might be the solinoid for the egr but wasn't sure, especially since it is in the wrong place. Can anyone tell me where the vacuum lines go? Right now the two small ones go to the egr and port under the throttle body driver's side. But there is a larger one not hooked to anything.
Old Apr 11, 2010 | 08:10 PM
my86corvette
I have looked but cannot find, even in the manual, a vacuum line schematic. Does anyone have one? I do have the factory manual on pdf but I can't find it there either.
Old Apr 11, 2010 | 08:13 PM
pologreen1's Avatar
pologreen1
Yep.
Old Apr 11, 2010 | 08:28 PM
floridamale
Old Apr 11, 2010 | 08:43 PM
floridamale
From what I understand when you go to order one they state no stock and no order date
I would buy one just to have if I could. There are a few past threads about this part also.
This one is from back in 08
http://forums.corvetteforum.com/c4-g...-solenoid.html
Old Apr 11, 2010 | 09:01 PM
my86corvette
Originally Posted by floridamale
Thank you very much!
Old Apr 11, 2010 | 09:25 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
You may have a very early '86 because the location you found it is where they are located on an '85.
Old Apr 11, 2010 | 09:32 PM
my86corvette
Build Date 10/85.
Should I just plug off the third vacuum port?
To What is this on the engine? Doesn't belong?
Old Apr 11, 2010 | 09:36 PM
John A. Marker
I think that just the two lines next to each other are used. I think you can leave the other one free.
Old Apr 12, 2010 | 06:38 AM
car5car's Avatar
car5car
Plug the line going to manifold. If you want to replace vac. switch you can probably use a switch from almost any car from junk yard. Just find GM of close year.
Old Apr 12, 2010 | 07:40 AM
ndanl's Avatar
ndanl
