Cooling System Help Please!
Old Apr 12, 2010 | 10:37 PM
F0RMULA's Avatar
F0RMULA
Default Cooling System Help Please!
87 z52 Coupe 4+3
Daily Driver
120k
I came outside to my car today to find most of the ground around it soaked with coolant. I drove home [only a few miles] keeping a close eye on the temp gauge. I jacked it up and began checking down the hoses. When looking under the car it appears to be dripping in the middle, right in front of the block.
I finally got a visual of where it was squirting from: directly in front of the block, a few inches to the passenger side, just south of the waterpump. The spraying looked like it was coming from one of the two hoses that lie behind the lower radiator hose. The only other 'hose' in that area has the plastic mushroom shaped end on it that looks like some sort of air sensor.
I replaced the waterpump, radiator, and both radiator hose just about a year ago, and they all are working fine. I need someone to tell me if its possible for it to be leaking out of one of those two hoses I mentioned, and if so, what are they called if I need to replace them.
If not, what else could it be in that area?
Thanks in advance for any help or input. I appreciate it.
Thanks.
Old Apr 13, 2010 | 10:24 AM
F0RMULA's Avatar
F0RMULA
Old Apr 13, 2010 | 11:03 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Ok, its probably worn hoses. replace them all and use new clamps.
IIRC those are heater hoses and route the coolant through the bottom of the throttle body.
Old Apr 13, 2010 | 11:15 AM
bjankuski's Avatar
bjankuski
They are the hoes for the oil cooler. Under the air conditioning bracket is a hose that looks like a (Y) and is is probably leaking.
Old Apr 13, 2010 | 12:40 PM
F0RMULA's Avatar
F0RMULA
i know the Y shaped hose you're talking about.
any idea what that is called or a part number?
thx
Old Apr 14, 2010 | 03:15 PM
F0RMULA's Avatar
F0RMULA
i am totally stumped.
i just spent 2 hours taking off the a/c compressor, that 'Y' hose, etc etc... checked all of the coolant hoses, and i cannot find any leaks.
The place I originally saw it squirting was in the area around that Y hose, lower radiator hose, and the two fuel lines that run by the frame.
I am completely stumped as to where else it could be coming from. The water pump is less than a year old , and both of its warning holes are bone dry. I inspected the lower radiator hose and it seemed fine (its only a year old as well).
any ideas?
Old Apr 15, 2010 | 09:31 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Blow dry the area and put a pressure tester on the rad. Pump it up and look again.
To Cooling System Help Please!
