Decided to change the plugs and wires on my 86 because they were quite old. Now that this has been done, it's running rough as hell. Any gas acceleration causes backfires. It was running smooth prior to the plug/wire change.
My first guess would be a crossed wire. Double check the order.
Mry '90 ran real rough after installing new plugs. Turned out, the gap was nearly closed on one plug when they were installed. Based on what you described, it either has to be one bad plug, or one wire isn't "clicked" onto the plug properly.
