Head gasket?
Old Mar 14, 2002 | 05:20 PM
siberianhusky911's Avatar
siberianhusky911
Default Head gasket?
Im going crazy. I posted 2 posts and one about white smoke coming for the car when i start it up and the other about it running real hot even for a vette. Every one keeps saying its sounds like a head gasket. But i just had a reman jasper engine put in 2 days ago That comes with a head gasket right? Some one mentioned did it smell sort of it has an odd odor but not that strong Its an 86 auto z-51 And i am going back to the shop monday but i want to ease my mind. :mad :mad
Old Mar 14, 2002 | 06:18 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Head gasket? (siberianhusky911)
Could be a bad reman job. I had a reman engine put in my 1990 Laser. It took them three tries before they sent the correct engine! OBTW valve covers are not included in the reman. It is possible that the Jasper reman was just the bottom end, which would mean your shop would have to reuse your old heads, etc.
Take it back and have them fix it under the warranty.
siberianhusky911
Please any thoughts?
Old Mar 14, 2002 | 06:23 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
It sounds like you have a bad reman. Could be head gaskets, could be poorly machined deck on the block or heads, could be warped heads, could be cracked castings, could be probably a bunch more things.
But one thing is clear, you need to take it back. You should not run that engine.
Pete
Old Mar 14, 2002 | 07:15 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Head gasket? (jaa1988)
Reman's come two basic ways. 1) Short block, with crank, rods, pistons w/ rings, cam & lifters, and sometimes the pan (with oil pump) Or 2) Long block, a short block with heads, and definitely the pan and oil pump.
Valve covers don't come with either, and are not a factor, here. If you bought a short block, the heads and head gaskets could be a problem. See my response to your "White Smoke" post.
Old Mar 14, 2002 | 07:38 PM
siberianhusky911
Default Re: Head gasket? (CFI-EFI)
The engine is a long block
Old Mar 14, 2002 | 11:10 PM
WINNER's Avatar
WINNER
Cruise-In II Veteran
Take it back and make them fix it under warranty :cheers:
Old Mar 15, 2002 | 03:57 AM
GlockLT4's Avatar
GlockLT4
Default Re: Head gasket? (WINNER)
yes, that definitely sounds like a head gasket to me.. get them to fix it.
To Head gasket?
