does this C Beam look normal?
Old Apr 15, 2010 | 11:53 PM
MP6's Avatar
MP6
Default does this C Beam look normal?
noticed this today. looks like it my be shaped like this to contour to the drive shaft. saw scrapes on the bottom of the c beam so i dont know. anybody look at theirs?
Old Apr 16, 2010 | 12:08 AM
littlesk8cracker's Avatar
littlesk8cracker
not normal!! replace it asap, the c-beam is a very important part of the car. holds all the mechanicals together!
Old Apr 16, 2010 | 12:09 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
looks like some bozo jacked the car up on the C beam.
I have one in my storage unit, and I can look at it tomorrow and let you know if it looks like that.
Old Apr 16, 2010 | 12:13 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
No, that is not a normal C-beam
Old Apr 16, 2010 | 12:39 AM
eguyett1985's Avatar
eguyett1985
Pete's right. That's not normal at all, replace it asap!
Old Apr 16, 2010 | 12:45 AM
subtlez28's Avatar
subtlez28
It is hard to tell w that pic, but I don't know.
I had a D44 and C-beam shipped to me recently. The box got it's butt kicked! I thought the C-beam was damaged because of the support structure (for the lack of a better word) looked bent. It obviously had the diff banging into it. However, once cleaned up it is so uniform, I feel it may be how it is shaped.
It may be damaged, I just wouldn't rush to judgement.
Old Apr 16, 2010 | 12:58 AM
Mark85Vett's Avatar
Mark85Vett
looks like it got run over!! Definitely incorrect!
Old Apr 16, 2010 | 01:58 AM
MP6's Avatar
MP6
could this be what is causing my car to shake and feel like insane tirehop under hard acceleration?
p.s. had my transmission replaced by a shop. not very happy right now. one of many complications i have had with their work.
Old Apr 16, 2010 | 02:06 AM
MP6's Avatar
MP6
i would GREATLY appreciate that!
Old Apr 16, 2010 | 03:06 AM
cv67's Avatar
cv67
St. Jude Donor '05
Check your torque converter
Old Apr 16, 2010 | 03:35 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Geez! That get shipped on a Tijuana donkey cart?
Old Apr 16, 2010 | 03:58 AM
The Green Rocket's Avatar
The Green Rocket
In regards to the OP's picture, I don't see what is troubling him - at least not from that picture. Yes its dirty, but even a pristine c-beam will not have perfectly straight sides.
As long as nothing is touching and the slignment is good, then no problem. I think the following will work on manual or auto trans: (Measurements taken from www.zfdoc.com) ALIGN DRIVELINE COMPONENTS: Take the following measurements directly above and to the right of the Propeller shaft front yolk universal joint. To ensure proper alignment of the driveline, a clearance of 45 mm +/- 6mm (1.77 in. +/- 0.236 in.) must be maintained between the top of the support to the underbody and a clearance of 28 mm+/-6 mm (1.1 in. +/- 0.236 in.) from the right side (passenger side of vehicle) of the support to the side wall.
There is something else that ZFDoc sells that helps with wheel hop c-beam issues, he calls them beam plates: http://www.zfdoc.com/c4beamplate.htm
Wheelhop can be cause by many issues, including:
1) worn shocks / old hard tires
2) seriously unbalanced wheels
3) aftermarket wheels with a hubcentric bore larger than 70.3mm - an uncentered wheel can trammel noticeably under acceleration.
4) driveline alignment
5) bad wheel bearings
6) bent or damaged suspension components
Sometimes it can be a process to discover the cause.
Thomas
Old Apr 16, 2010 | 01:32 PM
MP6's Avatar
MP6
sorry i forgot to mention that my car is a 92 six speed coupe.
also for got that my center resonator has a been crushed from the bottom up. but no damage on the top of the resonator.
Old Apr 16, 2010 | 01:42 PM
engle1147's Avatar
engle1147
I'm confused:
Was this damage done by the transmission shop or was all this stuff damaged prior to you buying the car and you just never noticed it before now?
Old Apr 16, 2010 | 01:50 PM
LD85's Avatar
LD85
FWIW, the C-beams do have a bow in them
Old Apr 16, 2010 | 03:02 PM
fc_soldier's Avatar
fc_soldier
Here are some pics I just took of a good c beam.
Old Apr 16, 2010 | 03:04 PM
fc_soldier's Avatar
fc_soldier
I guess you have a dana 44 I have a spare dana 36 (one in pic) for sale.
To does this C Beam look normal?
Old Apr 16, 2010 | 03:05 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Originally Posted by fc_soldier
Here you go....
Old Apr 16, 2010 | 03:10 PM
CAJUN C4's Avatar
CAJUN C4
Here you go....
LOL...That was great...
Old Apr 16, 2010 | 03:11 PM
fc_soldier's Avatar
fc_soldier
Here you go....
Thats cheating I use good ol polish. But as you can see its been awhile.
