Coilovers Installation (Rears).
Old Apr 22, 2010 | 10:44 AM
  #41
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Originally Posted by 94vettelover2
Anyone have issues with the spindle breaking(where the lower coil-over bolts to spindle)?Obviously it(spindle) was not designed for that.I would be concerned with breakage,especially with my luck.Is there anyway to reinforce that area where the coil-over mounts to the spindle?Or is it plenty strong & I am completely wrong?Could hitting a large pothole with the coil-overs cause spindle breakage?Or has the coil-over manufacturer already tested all "worst-case" scenearious?I think the coil-overs look great & offer lots of adjustablity but am I wrong in thinking there could be breaking which could lead to a bad accident or cause extensive damaged if/when it breaks?That area on the spindle was designed to damped the suspension not carry the weight of the vehicle.Can some coil-over guys that had their coil-overs for a while chime-in?Can some also post if their spindle has broken,cracked or fatigued in any way?Can any engineers or others post their ideas & opinions on my thoughts?
Few members stated they had their coilover set for 3+ years and never had issues with it. Members drive on tracks and streets. I'm going for mountain runs/twisties so if you hear that I went down a cliff , the coilovers failed.
Old Apr 22, 2010 | 04:30 PM
  #42
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
We don't use QA1 springs. QA1 only has 2.5" ID coils. We use a 2.25" ID coil on all 4 corners and we only use Hyperco OBD coil springs.
Old Apr 22, 2010 | 05:15 PM
  #43
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
That rear lower shock mount is one BEEFY dude. I was at their shop a few weeks ago (was cool to find out they are only 10 minutes from me) and got to check one out, they certainly have built a very nice coilover setup for the C4! If you shoot off the side of the mountain, I doubt it'll be from coilover failure.
Old Apr 22, 2010 | 05:16 PM
  #44
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
This is definitely a mod I am interested in. It's so clean, and looks pretty easy for the mechanically inclined. As for right now though, money is a bit tight.
I would like to ask though, where did you get that exhaust from? I will be replacing the stupid cheap tinny crappy sounding flowmasters the previous owned put in, and I like the ways yours is set up.
Old Apr 22, 2010 | 05:42 PM
  #45
PLRX's Avatar
PLRX
2017 C4 of Year
cool, now I can speed it up even more
Old Apr 24, 2010 | 01:05 PM
  #46
bdw18_123's Avatar
bdw18_123
From: Prather, California -1990 ZR-1 White/Flame Red- -SOLD!!-
Looks really good, Pete! I may have to do that mod to my '90 ZR-1 someday. When are you going to tackle the front install?
Old Apr 24, 2010 | 01:27 PM
  #47
PLRX's Avatar
PLRX
2017 C4 of Year
They are already in place but, I have to relocate or move the sway bar towards the front maybe 5/8".
Old Apr 24, 2010 | 02:02 PM
  #48
Coupe89's Avatar
Coupe89
St. Jude Donor '05-'06
I've had my coil overs system for 6 years. Not problems. Mine were from DRM. My next C4 will have them
Old Apr 24, 2010 | 02:50 PM
  #49
88BlackZ-51's Avatar
88BlackZ-51
I am looking forward to hearing what you think after putting the car threw it's paces!
Old Apr 24, 2010 | 10:26 PM
  #50
Black89Z51's Avatar
Black89Z51
What exhaust are you running PLRX? It is so clean.
Old Apr 25, 2010 | 12:31 AM
  #51
PLRX's Avatar
PLRX
2017 C4 of Year
Magnaflow but, I painted it with black ceramic high heat
Old Apr 25, 2010 | 03:28 PM
  #52
wdo-mkr's Avatar
wdo-mkr
6 plus years on my 91 zr1 with coil overs. It has been the track and the strip several times and never had a problem with the rear spindles. I have seen a couple photos over the years of broken spindles from coils overs. Most times it broke because a severe impact though, or because the shock was too long and it got completely compressed and the spindle was the weakest link.
Old May 23, 2010 | 12:10 PM
  #53
PLRX's Avatar
PLRX
2017 C4 of Year
UPDATE May 23, 2010
The rear was too high
I attempted to lower it but the coilover lowering plates hit the rod bolts and could not lower the coilover all the way. Van Steel
ordered shorter springs to accommodate desired ride height
Notice the coilover was slightly rubbing the driveshaft, means the upper shock mount needed to be relocated about 1/2" forward.
I drilled a hole 1/2' on my mount and a machine shop made me a set of washers for it.
I know I mentioned above on post #1 the frame would not need modification but, I have to grind the frame to accommodate the new set-up.
Old May 27, 2010 | 01:25 PM
  #54
lcvette's Avatar
lcvette
any updates on the setup?
Old May 31, 2010 | 10:44 PM
  #55
PLRX's Avatar
PLRX
2017 C4 of Year
Van Steel send a set of smaller/shorter springs but, they were too short and at the highest position it slammed the rear of the Vette down to the ground. The rear tires was barely touching the fender.
I disassembled all components and re-install the original spring.
In this picture you can see how the spring was rubbing against the half-driveshaft and I had to relocate the upper shock mount 1/2" towards the front.
Old Jun 19, 2011 | 09:14 PM
  #56
LD85's Avatar
LD85
Are all of the issues taken care of so far, I ma thinking about buying the Van Steel lower mount this week, I just don't have time to make my own
Does the rear lower shock mount pint stay close to the stock position?
As you know, there is limited space on the rear lower mount area. I just put new 375's on the rear and I hate the way the shock mount bolt is on that down angle
Old Jun 20, 2011 | 09:27 AM
  #57
Van Steel's Avatar
Van Steel
Here is the rear upper mount we now supply in the kit to move the shock forward.
http://www.vansteel.com/index.cfm?fu...p=1972&ID=3222
To Coilovers Installation (Rears).
Old Jun 21, 2011 | 09:35 AM
  #58
rickneworleansla's Avatar
rickneworleansla
Does it now come with this kit below or do you have to add it?
C4 Corvette Coil-Over System, Single Adjustable
QA1 Single Adjustable Coilover Shocks
Hyperco Coil Springs
2 Rear Lower Mounts
2 Front Upper Mounts
Spanner Wrenches
Price: $1,699.99 4 pcs
Old Jun 21, 2011 | 03:51 PM
  #59
Van Steel's Avatar
Van Steel
2 Rear Lower Mounts
Spanner Wrenches
Comes with it. I just have to update the site.
Old Oct 20, 2017 | 08:43 PM
  #60
PLRX's Avatar
PLRX
2017 C4 of Year
