Loose PCV Valve
Old Apr 20, 2010 | 09:29 AM
Murfnturf's Avatar
Murfnturf
Cruising
Default Loose PCV Valve
How loose should the PCV valve sit? On mine it seems to pull up and out with relatively little effort...seems to me like it should be snugger, there it some oil buildup around it which is lubing things up a bit. Can you replace the part that it sits in? OR is it possible it may have been replaced with a slightly too small valve? The end with the elbow and tube is snug, except it seems to rotate freely at teh connections.
Thanks for any insight
Old Apr 20, 2010 | 09:47 AM
JAKE's Avatar
JAKE
You could try changing the grommet.
Jake
Old Apr 20, 2010 | 09:49 AM
dogfish246's Avatar
dogfish246
Im assuming this is on an LT1. My PCV line is loosely attached the valve cover, but its pretty snug in the intake... Mine had very little oil around it though. Try cleaning it and getting it in there as snug as possible, then report back!
Old Apr 20, 2010 | 12:03 PM
Murfnturf's Avatar
Murfnturf
Cruising
It is a L98, but I will clean it first and see if that snugs things up. And it is the grommet in the valve cover that is loose fitting around the pcv valve.
Do the grommets shrink/wear thin over time?
Old Apr 20, 2010 | 01:04 PM
engle1147's Avatar
engle1147
The grommets get eaten up by the oil over time and they get all gummy so they loose their grip on the cover and the valve. Ensure that the hose that links to the PVC valve isn't trying to lift the valve up.
Old Apr 20, 2010 | 01:40 PM
turbow02's Avatar
turbow02
Cruising
Mine was loose as well. Cleaned it up and wrapped about 5 rounds of black electrical tape around it. Tightened it up nicely.
Old Apr 21, 2010 | 08:25 AM
Murfnturf's Avatar
Murfnturf
Cruising
I guess that makes sense. It does not appear that the hose is trying to lift the valve up. Thanks for the info!
Old Apr 21, 2010 | 08:26 AM
Murfnturf's Avatar
Murfnturf
Cruising
Suppose that would work for a quick fix...but it's a relatively inexpensive part...Why not fix it right?
Old Apr 21, 2010 | 08:34 AM
Joe C's Avatar
Joe C
Old Apr 21, 2010 | 08:59 AM
runner140*'s Avatar
runner140*
I agree! Alot like fixing a leaking radiator with "fix-a-leak". Always fix the problem.
To Loose PCV Valve
