MAF question
Old Apr 21, 2010 | 10:28 AM
HdRider04's Avatar
HdRider04
Default MAF question
86 stock motor
I am getting a maf code, and will be changing out the maf and releys, My question is does the MAF affect the start up idle?
When I now start the car in the mornings or after sitting a few hrs it idles @ 600. It used to be right about 1k until it went into closed loop but not anymore. Is this related to the maf or something else I have to look at?
Old Apr 21, 2010 | 03:24 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
You may have an IAC problem.
http://members.shaw.ca/agent86/IAC%20Diagnosis.pdf
Have you diagnosed the MAF code and is it the only code ?
Is the TPS idle voltage in spec ?
http://members.shaw.ca/corvette86/Code%2033.pdf
http://members.shaw.ca/corvette86/Code%2034.pdf
http://members.shaw.ca/corvette86/Code%2036.pdf
Old Apr 21, 2010 | 03:45 PM
HdRider04's Avatar
HdRider04
I replaced the IAC last week... TPS reset to .56 and no other codes
Old Apr 21, 2010 | 04:29 PM
engle1147's Avatar
engle1147
Short answer is yes - it can depend on the type of issue/failure the MAF is experiencing.
My advice is to tackle one issue at a time. Start with the MAF circuit since you have that set trouble code.
600 RPM is pretty much where you expect an automatic to idle once warm....so that is a good thing.
On an '86 - when you first hit the key on startup there is a cold start "switch" that is "open" or "closed" (depending on the temperature of the engine's coolant). This cold start switch enables an extra fuel injector (9th) to provide additional fuel to the engine upon start up. When the extra fuel is delivered by the 9th injector at startup you should expect the RPM to be a bit higher (up ~1000 or so) as a result. Perhaps your cold start circuit or injector needs attention if you have long crank times or other issues related to start up.
To MAF question
