Front outer tie rod stuck
Old Apr 22, 2010 | 01:33 AM
tarheelracer's Avatar
tarheelracer
Default Front outer tie rod stuck
I'm changing my tie rod ends and the passenger side tie rod end and jam nut are both stuck. I got the drivers side off easily. I went so far as to use an 18 inch pipe wrench and I can't get the tie rod end loose. Any ideas?
Old Apr 22, 2010 | 07:15 AM
Weav's Vet's Avatar
Weav's Vet
Some decent heat should do it.
Old Apr 22, 2010 | 10:20 AM
tarheelracer
I have to buy a torch, should I just get a propane one? I was really looking for an excuse to buy this one, but I'm pretty sure its a cutting torch.
http://skagit.craigslist.org/tls/1703010405.html
Old Apr 22, 2010 | 10:56 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
Soak it with penetrating oil and let it sit overnight. Do you have access to an impact gun?
Old Apr 22, 2010 | 11:23 AM
tarheelracer
I already soaked it in PB blaster and you can't get a impact gun on it. Only open end wrenches.
Old Apr 22, 2010 | 11:33 AM
383vett's Avatar
383vett
You are using 2 open end wrenches right? The left side has reverse threads compared to the right side. You might be trying to tighten the 2 nuts together.
Old Apr 22, 2010 | 02:52 PM
Clark Bente's Avatar
Clark Bente
What were your symptoms that made you change the tie rod ends?
Old Apr 25, 2010 | 04:55 PM
ramez75's Avatar
ramez75
I am also having the same problem but with the rear passenger side. I spent all day and i couldnt get the outer to separate. NExt weekend i will disconnect the inner tie rod from the crossmember and see if i can figure out a way to separate them
Old Apr 25, 2010 | 10:51 PM
94vettelover2's Avatar
94vettelover2
Heat works everytime.For a handheld cheap torch,don't get propane,get a map gas torch.Its puts out more heat than a propane but looks the same(cartridge).I have a handheld map gas torch that I got from the hardware store & it actually works greatI cannot afford a cutting torch as I've been laid off work for awhile.But I will definately get one as its the best tool you can have.But those portable cutting torch kits are around $350
To Front outer tie rod stuck
