Oil Leak
Old Apr 27, 2010 | 11:45 AM
DonF's Avatar
DonF
Default Oil Leak after rebuild
I have a LT4 that I just freshened up, rings & bearings & such. I put a Melling High Flow oil pump in it thinking that it would be better for Auto X. When I cranked it up oil came pouring out the two allen bolts that hold the bracket for the oil filter. The oil pressure was up & down going up to the first mark on the gauge & dropping down. I took the bracket off & put another gasket on with some prematex, let it set over night, same thing, but not as much oil as before but a steady stream. So I took it all apart & put the stock oil pump back on, I used the same spring that was on the high flow ( I think that this was my mistake, but I couldn't find the stock spring) when I cranked it up I had steady oil pressure on the high side but oil came out the same place again. I have talked to some of my friends that work on their cars & they have never heard of that problem.
Anyone else run into this? Any ideas would be greatly appreciated.
Old Apr 27, 2010 | 05:23 PM
DonF's Avatar
DonF
Bump
Old Apr 28, 2010 | 05:38 PM
DonF's Avatar
DonF
Any one!
Old Apr 29, 2010 | 11:55 AM
DonF's Avatar
DonF
Bump
Old Apr 29, 2010 | 12:11 PM
Red 91's Avatar
Red 91
Maybe try to define bracket? oil filter adapter? oilfilter/cooler adapter?
Old Apr 29, 2010 | 12:15 PM
engle1147's Avatar
engle1147
Weird
Bearings installed properly?
Old Apr 29, 2010 | 12:16 PM
engle1147's Avatar
engle1147
how about a pic of the leaky set up
Old Apr 29, 2010 | 12:30 PM
MK 82's Avatar
MK 82
Did you take the spin on adapter off? There is a large oring that seals it. Usually comes with the oil pan gasket kit.
Maybe you left the old one on. Shouldn't need permatex.
Old Apr 29, 2010 | 02:28 PM
DonF's Avatar
DonF
Bearings good, O'ring in place. Oil coming out the two allen bolts on the bracket that bolts to the block that holds the oil filter. There is a gasket that should prevent this but it isn't. I guess I will tear into the motor again to try & see some thing. This just doesn't make sence. No reason to take pics, oil coming out two fast any way.
Old Apr 29, 2010 | 04:07 PM
DonF's Avatar
DonF
Oil filter adapter
Old Apr 29, 2010 | 04:10 PM
DonF's Avatar
DonF
I have a stock oil pump spring now from a friend so I will try that & see what happens. I will let you know hopefully this wk. end.
Old Apr 29, 2010 | 10:08 PM
corvette95's Avatar
corvette95
isnt there an oil gallery plug that must be installed? its installed from the far side with a long punch?
Old Apr 30, 2010 | 01:59 AM
96GS#007's Avatar
96GS#007
Yep, little round ball that gets seated in the passage.
Old Apr 30, 2010 | 07:33 AM
DonF's Avatar
DonF
Intresting, where is this at? I have the pan off now, is this on the pump itself? Thanks
Old Apr 30, 2010 | 08:01 AM
corvette95's Avatar
corvette95
I tried to search for you, got to get to work, here is a start. search for oil passage plug installation small block chevrolet
http://forums.chevyhiperformance.com...oil/index.html
Old Apr 30, 2010 | 08:10 AM
corvette95's Avatar
corvette95
go to boxwrench.com or net ?
Old May 2, 2010 | 12:24 PM
DonF's Avatar
DonF
Couldn't find anything wrong so I put a stock spring back into the oil pump, fired it up no oil leak. I guess the other spring was too much. Thanks for you input.
To Oil Leak
