Who had cracked headers welded?
Old Apr 28, 2010 | 12:14 AM
gaguy's Avatar
gaguy
Default del
del
Old Apr 28, 2010 | 01:12 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Kinda depends on the crack. They're welded as part of manufacture, so they can be welded again (if in decent shape). I had a cast manifold welded on a Jeep that last 50k miles (when I sold it).
OTOH, buying used has gotta be cheap. Possibly cheaper than welding.
Old Apr 28, 2010 | 02:05 AM
tpi 421 vette's Avatar
tpi 421 vette
Originally Posted by gaguy
Is it a good idea to weld cracks of cast headers? Should I buy used ones?
You should probably mention exhaust manifolds rather than headers. Headers are steel tube, and manifolds are cast iron. The repair work will be different between the two materials. Cast iron is harder to weld than steel.
Old Apr 28, 2010 | 05:09 AM
cv67's Avatar
cv67
St. Jude Donor '05
Car5car.
Old Apr 28, 2010 | 08:08 AM
LD85's Avatar
LD85
Car5car.
I like long time
Welding cast can be done, where is the crack?
Old Apr 28, 2010 | 09:06 AM
Aardwolf's Avatar
Aardwolf
I had some welding done on a cast exhaust manifold on my old turbo car. I believe it should be nickle welded then the whole thing heated to relief stress. I had a local place do the work, it wasn't that much.
Old Apr 28, 2010 | 09:33 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Car5car.
Good catch, I agree.
Old Apr 28, 2010 | 09:44 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's been a while since I had stock exhaust manifolds, but I do not recall them being cast !!
Old Apr 28, 2010 | 10:51 AM
jmgtp's Avatar
jmgtp
I've welded cast exhaust manifold before (not vette).
I've heard it can be problems due to a high silicon content in the metal but I had no issue. Used stainless steel wire on a mig and it was easy, strong, and lasted.
Old Apr 28, 2010 | 10:59 AM
LD85's Avatar
LD85
Which one do you need, I have one I can sell from my 85
Old Apr 28, 2010 | 11:34 AM
GREGGPENN's Avatar
GREGGPENN
They're not. They're like the world's smallest sports car shorties! LOL
Old Apr 28, 2010 | 12:00 PM
pmihaltian's Avatar
pmihaltian
Slingshot
No, they are welded stainless steel tubing. At least thats what the OEM parts were.
Old Apr 28, 2010 | 02:04 PM
Aardwolf's Avatar
Aardwolf
My '88 100% had cast exhaust manifolds.
Old Apr 28, 2010 | 04:17 PM
black85's Avatar
black85
I've had it done successfully. You should take it somewhere that knows how to weld cast, and has a good oven to heat and cool it in. I've seen someone else try to do a cracked Porsche header without heating it first, and it just kept cracking more and more.
Old Apr 28, 2010 | 09:11 PM
GreyHairedTopGun's Avatar
GreyHairedTopGun
Default TIG weld it
Have someone who knows how to TIG weld do it. Depending on where the crack is, they might be able to get to it and cut a 45 degree 'V' along the length of the crack with like a Dremel tool or small air powered grinder. Then they will fill in the crack with rod, and probably make another pass over the top of that (called a cover pass) to completely fill it up. If they do it right, it will be very strong. TIG welding is the way to go, because you have very good control and the heat affected area is very small.
Old Apr 28, 2010 | 09:45 PM
black85's Avatar
black85
Just use it as an excuse to upgrade. I only welded the ones I did b/c there was no other alternative other than a custom header (turbo Volvo). Otherwise, just go to the for sale/wanted section and ask for stock headers for your year. If they are cast, there are a million people who ditched them for aftermarket stuff and are willing to sell that to you cheap. I would pretty much give away my stock 85 manifolds. Maybe there are other years with better manifolds/headers that would bolt right up. My guess is not the 1985 year. TPIS longtubes were a huge upgrade on mine.
To Who had cracked headers welded?
