Keyless Entry Tip
Old Mar 16, 2002 | 06:30 AM
merrick's Avatar
merrick
Default Keyless Entry Tip
If your remote seems intermittent or requires a shake to work, try cleaning the motion switch:
Open the remote case. The switch is the gold tit thing between the buttons. There is a small ball in there so don't lose it when you take the cover off. Remove the whole circuit board from the case and turn it over. Push the 2 gold tabs to pop off the cover. Clean with alcohol and reassemble. The ball is gold plated too(mine was grey with dirt).
Old Mar 19, 2002 | 12:28 PM
cire96's Avatar
cire96
Default Re: Keyless Entry Tip (merrick)
Merrick:
I have a 96 CE with the PKE system. Occasionally it goes into "flutter" mode ... the door locks partially open close at high frequency - or chatter. Do you suppose this tip has any bearing on that quirk? Thanks. Cire96 :cheers:
Old Mar 19, 2002 | 12:38 PM
Dan Parker '96's Avatar
Dan Parker '96
Thanks for the tip... I'll be doing that tonight....
Old Mar 19, 2002 | 01:50 PM
John Row's Avatar
John Row
Good Tip. You should post this under the TECH TIPs.
Thanks,
To Keyless Entry Tip
