Speed Bleeder Size
Old May 2, 2010 | 11:30 AM
umfan's Avatar
umfan
Default Speed Bleeder Size
I plan on ordering speed bleeders, does anybody know the correct size? JEGS shows alot of different sizes.
Old May 2, 2010 | 12:12 PM
c4cruiser's Avatar
c4cruiser
Get the original Speed Bleeders here
You want the SB1010 bleeders for both the front and rear calipers.
Old May 2, 2010 | 04:21 PM
Weav's Vet's Avatar
Weav's Vet
Originally Posted by joshwilson3
I wouldn't get speed bleeders. I'd get the Earl bleeders instead.
Why? I have them and so do a lot of others. No problems at all.
Old May 2, 2010 | 05:26 PM
Weav's Vet's Avatar
Weav's Vet
Because Speed Bleeders use sealant on the threads to keep air out, which the sealant can fail. Which is why they sell a bottle of their sealant so you can reapply it on the threads.
Earls use a plunger to keep air out. So, you don't have to worry about air getting in past the threads like can happen with Speed Bleeders.
I believe they are both around the same price, so might as well get the better design which is the Earl's.
Earl's:
Speed Bleeders:
Interesting, I've never had any problems with mine. I really don't see any difference whether it's a ball or plunger though. Could have just been dirty fluid that kept the SB from sealing properly. Crud has a tendency to do that.
Old May 2, 2010 | 05:50 PM
tombrammer's Avatar
tombrammer
Ok I have to ask the "dumb" question. Do "speed bleeders" mean you can bleed your brakes by yourself? If so do you have to have four and change the existing ones or just one and move from wheel to wheel? How do they shut off if you leave them in, do they just screw tight like the regular bleeder? Thanks, I want to get some of these. I have always just used a board against the seat and the pedal and then gone back and forth again and again to tighten loosen the bleeder. Learn something new every day here.
Old May 2, 2010 | 06:23 PM
Weav's Vet's Avatar
Weav's Vet
Also, although it is a basically a one man operation it makes it easier if you have someone watching the fluid flow into the bag to tell you when the air stops coming out.
They are handy little devils no matter which brand you choose.
Old May 2, 2010 | 06:40 PM
c4cruiser's Avatar
c4cruiser
I've had Speed Bleeders on my 87 for close to 5 years now. The bleeders get used 6-8 times per year and they still have the original sealant on them.
YMMV.
Old May 2, 2010 | 06:55 PM
Weav's Vet's Avatar
Weav's Vet
You just put a clear tube on the bleeder screw, and you can look at that yourself to see if there still is air coming out.
How you going to do that and push the brake pedal at the same time? Have hose 9' long? Or go back and forth trying to see if there are bubbles in the line. I'm just sayin it's easier with two not that it has to be done that way.
Old May 2, 2010 | 07:25 PM
Weav's Vet's Avatar
Weav's Vet
How do you know air isn't getting sucked in past the threads? I say it is past time to reseal the threads. Which is a pain as you have to clean them up and let dry. So, that means you have to get something to plug up the bleeder screw hole if you threw your old bleeder screws away.
I've just read enough of people saying they work fine, then start leaking later on, that I'd just buy Earl's. No worry about sealing up the threads.
What some guys say they do is just replace the speed bleeder screws every few years or everytime they flush the brake fluid and not worry about resealing the old ones.
Here is a review I read:
"Also, the Speed Bleeder screws rely on a sealant to keep air from being sucked into the system. This means that the bleeders must be annually (at least) removed and cleaned before new thread sealant (sold separately) can be re-applied."
http://octanereport.com/news/261/21/...ng-Screws.html
Now Josh, lets put the rest of the review on there.
"But, at only $7 for a regular version and $15 for a CNC-machined stainless version, the Speed Bleeder screw is one of the cheapest one-man brake bleeding options out there. It may not be as effective as having another human’s labor at your disposal, but it’s easy to carry, easy to figure out and makes a perfect backup for when you’re at the track or just need to get something done quick and by yourself. It’s the perfect parking lot emergency brake bleeding option."
Old May 2, 2010 | 08:07 PM
Weav's Vet's Avatar
Weav's Vet
After doing a little Googleing on the subject of sealant for these things, It seems that the usual cause for the sealant to start leaking is when people open the bleeder to far, like a turn or more or for some reason have to remove it completely. 1/4 turn is all it takes for fluid to come out in order to bleed the brake line. If it is turned very much more than that I can see why the sealant wouldn't last very long, nothing would. Maybe that is why some don't have any issues with them.
Old May 3, 2010 | 10:47 AM
GKK's Avatar
GKK
I use the Earl's Solo-Bleeds because I didn't like the Speed Bleeder's design.
Also, the original GM bleeder screws don't use sealant so, I'm not going to use anything that will gunk up the threads?!
To Speed Bleeder Size
