procedure for checking TPS voltage (L98)
Old Mar 16, 2002 | 02:39 PM
Vette9d1's Avatar
Vette9d1
Default procedure for checking TPS voltage (L98)
Does the car have to be running or the ignition on to test the voltage on the Throttle Position Sensor? Do you stick the leads with a pin to measure the voltage? Which colored wires do you test it with?
Old Mar 16, 2002 | 02:40 PM
scorp508's Avatar
scorp508
See my response in your other thread.
Old Mar 16, 2002 | 03:07 PM
Vette9d1's Avatar
Vette9d1
Default Re: (scorp508)
Sorry about the two posts; thought I had closed the window before I pressed post but I guess the system just bogged down.
To procedure for checking TPS voltage (L98)
