Opti question
I know you are getting the codes, but I would just like to get a look at the fuel pressure just to make sure the fuel pump is not cutting out.
I would sure would test, check and look at all I could (and use up all the beer) before I changed the opti. If nothing turns up, then go to opti land.
How often does it die, and does it start right back up?
My car does EXACTLY the same thing and is the same year. The only difference is my car is a manual, not an automatic, but I don't see what that should matter. You and I are going down the same road, but I have gone a little farther. I have replaced the opti-spark, ICM, PCM, opti-spark harness, fuel pump, AND fuel filter.
Note that I did not take a throw parts at it approach and see what happens, but still, here I am. Maybe I can save you some money in parts and we can figure this out together.
I replaced the fuel pump and filter just out of maintenance thinking that might be the problem, but when it didn't solve it, I started to really do some diagnosis. I bought the service manual and ran all the tests it called for. I even hooked up a data aquisition board from National Instruments and monitored these signals: high resolution signal from opti-spark measured at the PCM), low resolution signal from opti-spark (measured at the PCM), signal from PCM to ICM (measured at the ICM connector). Here is the video of those signals (http://www.screencast.com/users/russ...d-d49c91d430cf).
Let me know how much you know about the functionality and I can fill you in on what I've learned. There is a low res pulse from the distributor (8 pulses per cam revolution) and a high res pulse (180 pulses per cam revolution). The engine can fun on the low res pulse alone, but refines the timing with the high res pulse. Code 36 results when the low res pulse is present but the high res pulse is not.
You can see the low resolution signal on the bottom, high resolution signal in the middle, and signal to the ICM on top. I rev the engine and the frequency of these changes.
What is not on the video is what happens when the engine fails. Both the high res and low res lines go to 5V. I assume the distributor "biases" these lines when it is working correctly and pulls them low.
According to what I have read, code 36 results when the low res pulse is present but the high res pulse is not. When I replaced my opti the behavior changed. Before I replaced the opti, it would die at random just like yours and otherwise run perfectly, but there were no codes. After I replaced the opti, it took some time cranking (5-10 seconds) before it would start, but after starting it ran well except for certain situations. When on the freeway in 6th gear and floored, it feels like it misses every now and then. I also have code 36 stored now. My guess is that the high res pulse is no longer there and the timing is not as precise as what it needs to be resulting in a miss every now and then.
I plan to hook up the DAQ board again and scope these signals to see if the high res pulse really is gone. I think there is still a fundamental problem that I'm not finding. Let me know what you come up with and if you have any questions. I will keep you posted on my lack of progress. This has been going on for me now for five months.
Please keep me posted with any progress that you make and I will do the same for you.
so before trying to change the pcm check the harness attached to pcm first ,if nothing changed then chang the pcm.
i'll try to give you more details.
good luck
if a dtc 41and/or 42 is also set with a36 dtc,and no external fault can be found then replace pcm,if only 36 dtc is set and the opti connections are ok then replace opti distribitor.
the external fault menssioned the GM book is the harness shortcut or connections for pcm or opti distribitior or coil and coil module.
this note taken from GM service manual book -book2 section 6e3-a-82.
good luck
good luck
Thanks for the info.
I hope you have done some of the basics as suggested. The PMCs might be cheaper but harder to find. It bothered me you can't it to crap out in the driveway where you can take measurements. If you go for the PCM, I would hang on to my original one.
Well I bought the ignition switch and when it died I did what the look smith told me to do and it started,seemed just like the passenger reached over and turned off the key.I then checked the coil and no spark to the coil and no injector pulse.Replaced coil and car fired and ran for a few mths.It died again and I got pissed and shipped the car to my son.The car ran a mth and died.He took it to a chevy dlr (diamond chevy) near palmsprings.
They replaced the opti and the water pump.Car runs fine just like before,but now it over heats runs around 240 to 250 now and they want to replace the ecm because the fans come on to soon.
Now they found out they can't get the ecm so now it is a stale mate.
They say the water pump is good . The car was not over heating before it went in for the opti .Moral is the chevy dlr says we don't believe you! that it was not overheating and they just say the fans are coming on to soon, that is why the car is overheating,I do remember my mom taught me when the soup is hot to blow on it to cool it down .I guess she was wrong in what she taught me when I was younger.
They did get rid of the stalling problem
