bolt extractor snapped off
Old May 18, 2010 | 07:58 PM
jfb's Avatar
jfb
You could have been a multimillionaire with your tremendous luck, but no, not you, you had to use it all up in getting a broken ezyout removed. If you ever get one stuck and broken, get the grinder and stock up on grinder point stones.
Old May 19, 2010 | 01:40 PM
carguy604's Avatar
carguy604
Originally Posted by Midnight 85
You don't have much room to work with but if you could find an old bolt and sharpen the tip to a point. Stick the point in the hole you drilled and with a mig welder, (if you have one) weld the sharpened bolt to the broken one then immediately try to turn the whole thing out while it's still hot from welding. It will be touchy I admit, too bad the broken bolt wasn't a bigger diameter.
This method has worked for me in the past on other cars. It's particularly effective when the remaining bit of the offending bolt is above the surface. If the remaining bit of the bolt is above the surface, sometimes you don't even need to drill - just heat it up and weld it to another bolt. A squirt of penetrating oil afterwards has been useful too.
Old May 19, 2010 | 08:50 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
tried getting a tap extension today
I can't get the t-handle in there
all the ones I found were for a 7mm or smaller tap
a square drive would work
Old May 20, 2010 | 07:47 PM
BrianCunningham
a friend lent me a tap handle with a sliding handle
it's working
taking it easy so I don't break the tap
got it about 1/2 done
I'll finish it tomorrow.
some of the bolt's still in there.
I'm hoping at this stage that it's friction welded in.
Old May 20, 2010 | 07:54 PM
ch@0s's Avatar
ch@0s
it's working
Great news!!
Old May 21, 2010 | 05:19 PM
BrianCunningham
finished it up today
put a bolt in there just to make sure
of course the real test will be when I torque everything down.
Old May 22, 2010 | 01:09 AM
jfb's Avatar
jfb
Prayers said that you have enough thread to torque the bolt down!
What a tough job. On my 87, the bolt on one rear shock wouldn't turn, rust welded shut. We used a grinding cutoff wheel to cut the bolt through and hitting the bolt and rocking torque, it finally came out. Then the nut and 1/2 the bolt on the other side we rocked torque while I beat on the center of the bolt until it finally came out. All evening job. the replacement bolt, just like any other bolt I reinstall got antiseize applied to it. I feel for you!
