Rear hubs from ebay
Old May 14, 2010 | 09:41 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Originally Posted by MK 82
Nope! Spindle has to come out. Do it yourself. I have mine on order now and will install them in the next week. I already have the spindles out.
Eddie
I must have done mine wrong then - its accessible when the hub is off without removing the half-shaft.
I pulled the old one off, put the new washer on, put the new hub on, put on the outer washer and then the nut. All without removing the half-shaft.
Old May 15, 2010 | 12:18 AM
RedLS1GTO's Avatar
RedLS1GTO
Originally Posted by RedLS1GTO
SKF-BR930186 are the F-body fronts that work on later model C4s. I have them on my 96 right now.
Due to a recent pi**ed off forum member blaming me because he didn't do enough research, I am going to make this abundantly clear.
I CAN NOT (AND WILL NOT) CONFIRM THAT THESE SKF HUBS WILL WORK ON ANY CAR EXCEPT FOR MY 1996 COUPE.
I use them on mine with zero issues. Your results may vary.
Old May 15, 2010 | 04:08 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
WBI is where I bought the tapers for the GP.
And trust me, the price for NOS? Are these really NOS?
I'm not willing to pay the extra $ for a part advertised as NOS for double the price. Go with WBI.
They also supply the production lines in Detroit. Thats close enough to NOS for me.
BTW.....ALL C4 rear wheel bearing are the SAME!
nuff said
Old May 15, 2010 | 04:30 PM
MK 82's Avatar
MK 82
How did you get to the four bolts that hold the hub on with the spindle and halfshaft in place? Must have taken some contorsions.
This is of a 96 which does not have the drum and shoes. Not sure which year it changed.
Old May 15, 2010 | 04:48 PM
samsonb's Avatar
samsonb
From what I've read. You have the car in neutral. And rotate the shaft so you can get to the 3 hub bolts. I thought there were just 3 hub bolts?
I know when I priced out labor, I don't think most of them pull the shaft. As one shop gave me a really high price of $300. And I asked why it was so high compared to other shops. And he said it shows to pull the half shaft. I'd go elsewhere anyways. I'm sure the shop would take a short cut and not pull the shaft, but charge $300 in labor anyways. The cheapest labor I got was $87.
Old May 15, 2010 | 04:57 PM
floridamale's Avatar
floridamale
This is not that bad of a project to do on your own. I did mine, and would never pay some one to to u joints or a bearing replacement it's a couple hours work tops. And it is only 3 bolts to get the hub off.
Old May 15, 2010 | 05:22 PM
MK 82's Avatar
MK 82
I have a headache!
I did mine while I had the halfshafts out to R&R the U Joints. There are many ways to skin a cat. And it is three bolts. I forgot!
Actually I am still waiting for the washers to arrive.
Drive it to my house and I will do it for a 6 pack.
Eddie
P.S. Be glad we are not talking about the lug nuts on my Motorhome. 450 FT/LBS!! I have a 4 Ft cheater pipe.
Old May 15, 2010 | 05:27 PM
floridamale
I used a 1/2 breaker bar on the 3 torx bolts. I did not have any trouble breaking them loose, make sure you clean out any dirt that is inside so you get a good bite with the T55. If I remember right I use a gentle tap on the socket then hooked the breaker bar to it. The retainer just slips over the axle nut and the cotter pin locks it in place you can remove it with your fingers after the pin is out. They use this set up instead of a castle nut with a pin. I have one of those lug tools but I think the slight angle on it didn't allow me to use it, the breaker was a better angle. Buying tools is never a bad thing you need to have them anyway for the next project.
Old May 15, 2010 | 05:30 PM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
Yes, trans in neutral, rotate half shaft so the u joint strap is out of the way, unbolt the three bolts.
If you found someone that will do it for $87 and will stand behind it - have them do it!
As for the nut retainer it just slips on over the nut. Put a new cotter pin in and you are good.
Old May 15, 2010 | 06:17 PM
MK 82's Avatar
MK 82
Dude!! It is not a nut. It merely serves to keep the nut from backing off.
Old May 15, 2010 | 07:49 PM
gaguy's Avatar
gaguy
Some mechanic said that he always removes seal and grease bearings. He also said some of them didn't have grease at all.
I don't know if it doable for rear bearings.
Old May 17, 2010 | 01:16 AM
C4boy's Avatar
C4boy
Autozone has a 200 ft/lb torque wrench you can rent for free and the socket shouldn't be $20.
Old May 17, 2010 | 01:33 AM
  #33
C4boy's Avatar
C4boy
You're turning this into more of a project than you need to
Measure your torque wrench against a rental one and see how they match up - use your lug nuts as a gauge. Read through the shop manual or one of Agent86's PDF files too
Old May 17, 2010 | 02:02 AM
  #34
86PACER's Avatar
86PACER
Autozone does have a 200 ft lb 1/2 drive torque wrench as well as 6 point spindle nut sockets in several sizes.
You need the 36mm socket.
If that bastard is on there rediculosuly tight (which is usually the case on one side) that even a huge breaker bar with pipe extensions won't budge it, I just drive around the corner to the tire shop and have a guy loosen it in half a second with an air gun for a small tip. Then I drive back home and finish the job instead of breaking my back.
nuff said
Wheel Bearings Inc are us made. Most AC Delco parts are now made offshore.
How many miles on your tapered set? Still tight?
Wheel Bearings Inc. adds "HD" to their standard bearing part number for their taper bearing unit.
But they no longer sell directly to the public off their site like they used to at about $60 a piece for the rears. You have to purchase them from one of their authorized "distributors". Unless you contact them to find out who sells their units it's hard to tell what you're getting because wheel bearings get reboxed all the time.
Old May 17, 2010 | 02:06 AM
  #35
JrRifleCoach
Aww Geez Josh!!!
Tighten the S**T outta it!!
Use a two foot lever and hang your weight off the end. If your 100 lbs that will apply 200 foot pounds.
And your wheels will not fly off...... if you remember to install the cotter pin.
Old May 17, 2010 | 02:17 AM
  #36
86PACER's Avatar
86PACER
I couldn't tell you.
You should replace both coated washers behind the hub while you're in there (red arrow in pic). One on each side. They can become a source of noise. Put anti-seize on the splines and tighten the spindle nut with car still on jackstand.
Old May 17, 2010 | 10:15 AM
  #37
MK 82's Avatar
MK 82
Aww Geez Josh!!!
I told him that already. I think he likes the attention.
To Rear hubs from ebay
Old May 17, 2010 | 01:22 PM
  #38
floridamale
Old May 17, 2010 | 03:29 PM
  #39
samsonb's Avatar
samsonb
Then why aren't you following that advice? You still pull out a 150 ft/lbs torque wrench, which is alot better than not having one at all and just guessing with your body weight. I never asked how to torque down that nut anyways as I already stated I was gonna use a torque wrench.
Just because someone told me to go out there and use my body weight and guess that it is tightend to spec, doesn't mean I have to do it that way. I can do it however I want. I'm the one that has to fix it if something gets messed up, so I figure I'd do it the right way and torque it down to spec instead of just guessing. So, I don't see a problem with pulling out a 200 ft/lbs torque wrench instead of just guessing at it.
Old May 17, 2010 | 10:08 PM
  #40
JrRifleCoach
Cmon Josh, your killing me.
