TTS Datamaster sync problem with 92 Vette
Old May 14, 2010 | 09:26 PM
RACEON1967's Avatar
RACEON1967
3rd Gear
Default TTS Datamaster sync problem with 92 Vette
92 LT1 auto, TTS Datamaster version 4. When I try to log data it syncs up, then goes out, resyncs etc etc.
TTS says to change the serial recieve and transmit timeouts from zero to 180.
Any other suggestions as I am trying to use my netbook with this, and my large laptop works fine with same OS, but older laptop. The netbook is an ASUS and all USB ports work fine. I have used TTS for years, but never had this problem with this cable. The only thing different is the laptop, yet bot laptops us WXP.
Old Jul 3, 2010 | 11:47 AM
aboatguy's Avatar
aboatguy
I had that problem with version 4.0
I rolled back to version 3.51 and all is well again.
I''ve been using a Asus EEE 1000HD for a couple of years now..
Mike
Old Aug 6, 2010 | 04:35 PM
Daniel DK's Avatar
Daniel DK
if you disable dash updates/refresh it will sync... ofcurse then the dash won't refresh
Old Aug 14, 2010 | 02:08 PM
rickso84's Avatar
rickso84
Where can I find Datamaster ver. 3.5.1?
Old Aug 16, 2010 | 09:35 AM
rickso84's Avatar
rickso84
"Disable dash updates" did the trick for me so now I can use version 4.0. Thanks for the suggestion!
To TTS Datamaster sync problem with 92 Vette
