Replacing Motor Mounts
Old May 18, 2010 | 10:57 AM
Thomastp's Avatar
Thomastp
Default Replacing Motor Mounts
I'm replacing the motor mounts on my 94 6speed. I have the exhaust off and the cats off. I can't seem to get enough clearance to get the mounts out. I have a jack under the bell housing and it seems like the bell housing/trans has contacted the tunnel and I can't get any more room. Is there a trick to this. The heat shields are also a problem. Thanks in advance for any help.
Old May 18, 2010 | 11:09 AM
383vett's Avatar
383vett
Pull the motor mount bolt. Unscrew the 3 bolts holding the motor mount to the block and you should be able to get the mount up and off. The bolts are hard to access but doable.
