Spark plug replacement tips
Old May 22, 2010 | 06:32 AM
corvette95's Avatar
corvette95
I have a set of hollow sockets that fit over and the plug goes through the socket and the socket wrench then fits around the socket, its a store bought version of what the prior poster said about his cut off socket. The set is between 50 and 150 bucks depending on quality.
Old May 22, 2010 | 09:56 AM
STL94LT1's Avatar
STL94LT1
Originally Posted by WW7
These 2 suggestions above are the best tips you will get, also don't over tighten the plugs, put them in till they touch, then go just a little more till snug and you can feel the washer start to crush....WW
The LT1 spark plugs don't use washers.
